1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Delta Tau Turbo PMAC2 VME Ultralight A24/A32 VME address space problem
To: <[email protected]>
Date: Thu, 6 Nov 2014 16:10:06 -0600
The attached screen shot may be easier to follow.
Ron
On 11/6/2014 2:05 PM, Ron Sluiter wrote:
FYI,
After several months of investigating various and intermittent problems here at the APS, I have finally determined that the root cause of these problems is the Delta Tau Turbo PMAC2 VME Ultralight's VMEbus interface.  A Turbo PMAC2 VME Ultralight, whose DPRAM is configured for A24, will respond to a A32 write cycle if it is preceded by a A24 write cycle to the PMAC's DPRAM and the A32 write cycle has the same lower 24 address bits as the A24 write (confusing, I know. See the five VMEbus transaction steps below).
I have a test program that I use to drive VMEbus data collection on a VMETRO VMEbus analyzer. The test program is NOT definitive; it is sensitive to both compiler optimization (only works without optimization) and out-of-order bus transactions; but the VMETRO data IS definitive.
The order of bus transactions to create a failure is;
  1. A24@0x70 0674 write 0x1000 to PMAC DPRAM
  2. A24@0x70 0674 read 0x1000 from PMAC DPRAM (this step is to confirm the previous write, not really a required bus transaction)
  3. A24@0x70 0EA0 write 0x4000 to PMAC DPRAM
  4. A32@0xA070 0674 write 0x8000 to Hytec DAC8402 DPRAM, or MAXv DPRAM, or no DPRAM (the problem occurs even if this bus transaction results in a VMEbus BERR)
  5. A24@0x70 0674 read 0x8000 from PMAC DPRAM (this step confirms that step #4 resulted in a write to the PMAC's DPRAM)
Steps #3 and #4 are key.
The same problem occurs if the PMAC is configured for A32 and step #4 is a write to the A24 address space.
I was in contact with Delta Tau on this problem.  They informed me that "this is a product that will soon be placed on legacy status" and there is no plan for a fix.  The work-a-round is to make sure that the low order 24 bits of the PMAC-VME DPRAM and mailbox address spaces are unique in both the A32 and the A24 VMEbus address spaces.
Ron
Attachment: PMACErrTstStateMode.png
Description: PNG image
Delta Tau Turbo PMAC2 VME Ultralight A24/A32 VME address space problem Ron Sluiter
Prev: Delta Tau Turbo PMAC2 VME Ultralight A24/A32 VME address space problem Ron Sluiter
Next: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
