1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn and stringin records
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Nov 2014 16:26:14 +0000
Hi Freddie,
This is the current code that handles the interrupt callbacks for the stringin record.  You are definitely correct that it does not guaranteed that the string is null terminated.
This is the code for periodic reads. It does guarantee that the string is null terminated.
static void callbackSiRead(asynUser *pasynUser)
    devPvt         *pdevPvt = (devPvt *)pasynUser->userPvt;
    stringinRecord *psi = (stringinRecord *)pdevPvt->precord;
    size_t         nBytesRead;
    asynStatus     status;
    size_t         len = sizeof(psi->val);
    status = readIt(pasynUser,psi->val,len,&nBytesRead);
    psi->time = pasynUser->timestamp;
    if(status==asynSuccess) {
        psi->udf = 0;
        if(nBytesRead==len) nBytesRead--;
        psi->val[nBytesRead] = 0;
    finish((dbCommon *)psi);
This is the code for I/O Intr scanned records. It does NOT guarantee that the string is null terminated.
static void interruptCallbackSi(void *drvPvt, asynUser *pasynUser,
       char *data,size_t numchars, int eomReason)
    devPvt         *pdevPvt = (devPvt *)drvPvt;
    size_t         num;
    pdevPvt->gotValue = 1;
    num = (numchars>=MAX_STRING_SIZE ? MAX_STRING_SIZE : numchars);
    strncpy(psi->val,data,num);
    psi->udf = 0;
    if(num<MAX_STRING_SIZE) psi->val[num] = 0;
    /* Set the status from pasynUser->auxStatus so I/O Intr scanned records can set alarms */
    if (pdevPvt->status == asynSuccess) pdevPvt->status = pasynUser->auxStatus;
    scanIoRequest(pdevPvt->ioScanPvt);
I propose to change this to:
    size_t maxChars = sizeof(psi->val)-1;
    if (numchars > maxChars) numchars = maxChars;
    strncpy(psi->val,data,numchars);
    psi->val[numchars] = 0;
    psi->udf = 0;
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Friday, November 07, 2014 9:58 AM
To: [email protected]
Subject: Asyn and stringin records
I have come across a difference in behaviour with asyn and the EPICS stringin record (asyn 4-22 / base 3.14.12.2 / win64) that occurs when the value received by the driver happens to be larger than the stringin maximum size. A record was changed from "periodic scan" to "I/O Intr" resulting in a crash due to a strcpy() (in monitor() from stringinRecord.c of base) being unable to find a NULL terminator and thus overwriting memory. Looking at devAsynOctet.c  it seems that stringin records that are periodically scanned are always guaranteed to have a NULL terminated value, whereas ones processed via interruptCallbackSi() are NULL terminated only if the data received is less than 40 characters long (I noticed that in base 3.14.12.4 the stringinRecord.c monitor() routine now uses strncpy() and so does not require NULL termination). For my case I've just added NULL termination for "I/O Intr" too, but from looking at the stringin record reference manual page I wasn't sure if the ori!
 ginal I/O Instr stringin behaviour was actually more correct?
Freddie
Scanned by iCritical.
RE: Asyn and stringin records Mark Rivers
Asyn and stringin records freddie.akeroyd
Prev: Re: Permissible in C to call CA I/O functions from callback? Andrew Johnson
Next: Re: Problems with Dynamic Array population Brown, David L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Asyn and stringin records freddie.akeroyd
Next: RE: Asyn and stringin records Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
