Hi Zunbeltz,
Have you looked at the Troubleshooting section in the areaDetector Viewers documentation?
http://cars.uchicago.edu/software/epics/areaDetectorViewers.html#Troubleshooting
The EPICS areaDetector ImageJ viewer creates a diagnostic log window that probably has error messages in it.
I suspect that your problem is that you need to set the environment variable EPICS_CA_MAX_ARRAY_BYTES to a value that is at least as large as the biggest image you want to transport over Channel Access. In your screen shots the images are 1024x1024 16-bit. That means EPICS_CA_MAX_ARRAY_BYTES needs to be at least 2MB=20897152. I would recommend setting it to 10000000 in case you use some larger cameras as well.
The EPICS_CA_MAX_ARRAY_BYTES environment variable needs to be set on both the Windows machine running the EPICS IOC and on the client machine that is running ImageJ.
From: [email protected] [[email protected]] on behalf of zunbeltz [[email protected]]
Sent: Monday, November 10, 2014 4:58 AM
To: [email protected]
Subject: areaDetector and ADRoper; view files in imageJ
Dear all,
I got running areaDetector with a PI-MAX camera using the ADRoper driver.
In my setup the camera is controlled by the ioc server in a windows machine.
Use MEMD to acquire the photos from a remote linux machine.
I manage to connect imagej to the acquired image; but it is completely
black ( all the bytes 0).
The configuration used can be seen in the attached fiels.
I try to change the file format from SPE to TIFF (16 bit and 8 bit) but
I always get a 16 bit black image in imageJ.
(I have installed the SPE plugin).
Any idea where can I look?
Best regards,
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
- Re: areaDetector and ADRoper; view files in imageJ zunbeltz
- areaDetector and ADRoper; view files in imageJ zunbeltz
<2014>
2025
<2014>
2025
