1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monotonic time from EPICS Base libCom?
To: [email protected]
Date: Thu, 13 Nov 2014 17:27:48 -0600
On 11/13/14 4:57 PM, Michael Davidsaver wrote:
> Strictly speaking epicsTimeGetCurrent() does try to prevent backwards
> jumps.  Subsequent calls should never return later values.  Of course
> in some cases this means that time stops...
Hi, Michael.
Thank you for your reply.  I see; I didn't know that epicsTimeGetCurrent
prevents backward jumps, but I guess this is probably what Kay was
alluding to when she mentioned that "generalTimeGetExceptPriority()
checks for monodic behavior."
So, I guess I should clarify that I'm interested in something like
POSIX's clock_gettime using the CLOCK_MONOTONIC clock ID.
Still, as you noted, epicsTimeGetCurrent can result in time that stops
and, in my example, an actual timeout that is longer than what the
caller requested, whereas a POSIX CLOCK_MONOTONIC clock would not have
that problem.
> I think it wouldn't be difficult to add a real monotonic time source
> which defaults to epicsTimeGetCurrent() for platforms without such a
> time source.  POSIX has clock_gettime w/ CLOCK_MONOTONIC and similar
> (RTEMS implements this).  Windows has something as well.  Not sure
> about vxWorks.
PEP 418, while obviously for Python, does include an overview of time
functions available on different operating systems as well as some
references on the subject, so it might be a help for implementing this
on other platforms supported by EPICS:
  http://legacy.python.org/dev/peps/pep-0418/
> https://bugs.launchpad.net/epics-base/+bug/1392516
Thanks for creating that!
Lewis
Monotonic time from EPICS Base libCom? J. Lewis Muir
Re: Monotonic time from EPICS Base libCom? Michael Davidsaver
Prev: Re: Browser based EPICS GUI Jani Hakala
Next: Re: Browser based EPICS GUI Ryan Pierce
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monotonic time from EPICS Base libCom? Michael Davidsaver
Next: Can pvTimeGetCurrentDouble fail to set its argument? Ben Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
