1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: epicsqt QETable or QElabel for waveforms readout
To: "Alexander S. Aryshev" <[email protected]>, "[email protected]" <[email protected]>, EPICS mailing list <[email protected]>
Date: Fri, 21 Nov 2014 09:00:39 -0800
Alex,
Here is an example of QELabel
http://www.epicsqt.org/wiki/ForEveryone/ForSysadmins/QeFrameworkOverview#Instantiate_your_first_QE_widget
This covers the minimum code for a QELabel.
BTW I still intend to have a long discussion with you about the status of KwT
http://sourceforge.net/projects/kwt/
I'll contact you early next year.
Emmanuel Mayssat
> Date: Fri, 21 Nov 2014 14:58:18 +0900
> From: [email protected]
> To: [email protected]
> Subject: epicsqt QETable or QElabel for waveforms readout
> Dear QTi-talk,
> I am trying to access waveform data of QETable
> to assign them to a local array or QVector.
> I have also tested QELabel and did not succeeded
> at all.
> Please suggest (or even better send me a one-line example)
> what function of QETable or QElabel I should use.
> My environment is a s follows: Qt base 5.3.2,
> Qtcreator 3.2.2, epicsqt 2.9.0
> With the best regards,
> Alex
RE: epicsqt QETable or QElabel for waveforms readout Emmanuel Mayssat
Prev: RE: IOC in EPICS v4 C++ Ganesh Jangir
Next: Re: Small bug in caget Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Beckhoff EtherCAT Motion Control [SEC=UNCLASSIFIED] graham.cox
Next: RE: epicsqt QETable or QElabel for waveforms readout Emmanuel Mayssat
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
