1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Motion Controller for Newport XPS q8 installation
To: "'uadly'" <[email protected]>
Date: Mon, 24 Nov 2014 17:10:23 +0000
Hi Martin,
This is because you are using a new version of the sequencer that breaks backwards compatibility in C functions that use seq_pvPut and seqPvGet.
I have not tried 2.2.0.2.
The last tech-talk message on this topic that I could find was this one:
http://www.aps.anl.gov/epics/tech-talk/2014/msg01408.php
As I read that Ben was considering rolling back the breaking incompatibilities, so we have not modified the motor code to use the new syntax.
Can you roll back to a previous release of the sequencer?
-----Original Message-----
Sent: Monday, November 24, 2014 10:36 AM
To: Mark Rivers
Cc: [email protected]
Subject: Motion Controller for Newport XPS q8 installation
Hey Mark,
i tried and failed to compile your motion controller R6-8-1.
I tried on two different PCs with different systems without any success.
First OS: Ubuntu 14.04.1 LTS
Compiler: gcc 4.8.2
Second OS: Fedora release 20 (Heisenbug)
Compiler: gcc 4.8.3 20140911
On both systems the following software/modules are installed:
-EPICS base-3.14.12.4
-asyn4-24
-busy-1-6-1
-ipac-2.11
-seq-2.2.0.2
The compiler shows following:
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500          -Wno-write-strings  -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/sauter/epics/asyn/include  -I/home/sauter/epics/seq/include   -I/home/sauter/epics/base/include/os/Linux -I/home/sauter/epics/base/include  -I/home/sauter/epics/ipac/include       MM4005_trajectoryScan.c
../MM4005_trajectoryScan.st: In function 'seqg_action_trajectoryScan_0_execute':
../MM4005_trajectoryScan.st:384:40: error: called object is not a function or function pointer
             startTime = time(0);
../MM4005_trajectoryScan.st: In function 'seqg_action_trajectoryScan_0_wait_execute':
../MM4005_trajectoryScan.st:425:31: error: called object is not a function or function pointer
             if (difftime(time(0), startTime) > expectedTime*timeScale*2.) {
../MM4005_trajectoryScan.st: In function 'getEpicsMotorMoving':
../MM4005_trajectoryScan.st:645:9: error: too few arguments to function 'seq_pvGet'
         seq_pvGet(ssId, pVar->epicsMotorDoneIndex[j], 0);
In file included from /home/sauter/epics/seq/include/seq_snc.h:30:0,
                 from MM4005_trajectoryScan.c:7:
/home/sauter/epics/seq/include/seqCom.h:76:23: note: declared here
 epicsShareFunc pvStat seq_pvGet(SS_ID, CH_ID, enum compType, double tmo);
../MM4005_trajectoryScan.st: In function 'waitEpicsMotors':
../MM4005_trajectoryScan.st:665:13: error: too few arguments to function 'seq_pvPut'
             seq_pvPut(ssId, pVar->motorCurrentIndex[j], 0);
/home/sauter/epics/seq/include/seqCom.h:79:23: note: declared here
 epicsShareFunc pvStat seq_pvPut(SS_ID, CH_ID, enum compType, double tmo);
../MM4005_trajectoryScan.st:671:9: error: too few arguments to function 'seq_pvPut'
make[3]: *** [MM4005_trajectoryScan.o] Error 1
make[3]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp/NewportSrc/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp/NewportSrc'
make[1]: *** [NewportSrc.install] Error 2
make[1]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp'
make: *** [motorApp.install] Error 2
I'm looking forward for your advice
sincerely
Martin
Motion Controller for Newport XPS q8 installation uadly
Prev: Motion Controller for Newport XPS q8 installation uadly
Next: rebootHookAdd() equivalent for OSI / RTEMS? Mike Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
