1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: xsubpp moved under Sscientif Linux 7.0
To: [email protected]
Date: Mon, 01 Dec 2014 08:23:09 -0500
A more (OS) portable way to accomplish this
XSUBPP = $(firstword $(wildcard /usr/bin/xsubpp $(EXTUTILS)/xsubpp))
On 12/01/2014 05:43 AM, Torsten Bögershausen wrote:
> Hi,
> I tried to compile EPICS under "Scientific Linux release 7.0 (Nitrogen)"
> It failed, because xsubpp is no longer here:
> /usr/share/perl5/Extutils/xsubpp
> but found here:
> /usr/bin/xsubpp
> Thanks to Götz, who helped me debugging the error and finding a fix.
> For now I added a shell script to see where xsubpp is.
> The following applies to base-3.15.1-rc1 (but the problem is in older
> bases as well)
> Does this sound reasonable, or are there better ways ?
> diff --git a/src/ca/client/perl/Makefile b/src/ca/client/perl/Makefile
> index 6ae32dd..516e494 100644
> --- a/src/ca/client/perl/Makefile
> +++ b/src/ca/client/perl/Makefile
> @@ -54,10 +54,11 @@ include $(TOP)/configure/RULES
>  ifdef T_A
>    EXTUTILS = $(shell $(PERL) ../perlConfig.pl privlib)/ExtUtils
> +  XSUBPP = $(shell if test -x /usr/bin/xsubpp ; then echo
> /usr/bin/xsubpp ; else echo $(EXTUTILS)/xsubpp ; fi)
>    %.c: ../%.xs
>         $(RM) $@ $@_new
> -       $(PERL) $(EXTUTILS)/xsubpp -typemap $(EXTUTILS)/typemap $< >
> $@_new && $(MV) $@_new $@
> +       $(PERL) $(XSUBPP) -typemap $(EXTUTILS)/typemap $< > $@_new &&
> $(MV) $@_new $@
>    $(INSTALL_PERL_MODULES)/$(PERL_ARCHPATH)/%: %
Re: xsubpp moved under Sscientif Linux 7.0 Andrew Johnson
catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
Prev: xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
Next: RE: Is it possible for an Asyn output record to be, also, an (I/OIntr - driven) input? Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: xsubpp moved under Sscientif Linux 7.0 Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
