1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strip Chart widget in EDM
To: "Kasemir, Kay" <[email protected]>, "Sinclair, John William" <[email protected]>, <[email protected]>
Date: Tue, 2 Dec 2014 16:48:41 -0300
OK, thanks.
I added the support back in to the current version of EDM and it seems to work fine for us.
It seems such a handy widget. Surprised that no one else uses it.
On 12/01/2014 03:14 PM, Kasemir, Kay wrote:
Hi:
I had added some string chart widget to EDM way back, it had very little use here at the SNS.
I assume John had to remove it because it had some problems and nobody missed it so far.
If you were happy with it, and you can get the older code to compile, you're more than welcome to add it back into your copy of EDM.
Kay
On Dec 1, 2014, at 10:58 AM, Mike Westfall <[email protected]>
  wrote:
A question probably best answered by Kay Kasemir:
It seems that StripClass support in pvFactory has been removed from the latest versions of EDM.
Was there a particular reason for this?
What do I risk by adding it back in?
Mike Westfall
Gemini Observatory
Colina El Pino S/N, Casilla 603
La Serena, Chile
Tel: +56 51 2205625
RE: Strip Chart widget in EDM Sinclair, John William
Strip Chart widget in EDM Mike Westfall
Prev: Using EPICS with Attocube stepper motor Ana Malagon
Next: EPICS 3.15.1 Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Strip Chart widget in EDM Mike Westfall
Next: RE: Strip Chart widget in EDM Sinclair, John William
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
