While we're at it...
On 03/12/2014 16:44, Mooney, Tim M. wrote:
For any synApps module, you should include <module>Support.dbd, and not <module>.dbd, because <module>.dbd is what the module builds for its own use, while <module>Support.dbd is what it builds for export to other modules. For autosave, the names are as.dbd and asSupport.dbd.
This is indeed the synApps model of naming things, but synApps is a bit
special in this regard.
The more common pattern is to have <module> export <module>.dbd for
inclusion by applications, and I would lean towards proposing synApps
make a step in that direction.
What is "its own use" for a support module anyway? By definition, a
support module provides a library and resource files (like dbd files and
db templates) that go with it. Tests and examples should rather be moved
into embedded self-contained TOP structures - 3.15 provides convenient
Makefile rules to do that. This has multiple advantages: it clearly
separates support module and example code (inexperienced users usually
can't tell which is which in the existing mixed modules, and create
worse applications as a result), and it allows simply copying out the
complete embedded example tree into their own work area (requiring only
a change in the configure/RELEASE file to locally build a correct full
example app).
Just my 2.5ct...
~Ralph
- RE: FW: EPICS 3.15.1 Mooney, Tim M.
- EPICS 3.15.1 Dudley, David
- FW: EPICS 3.15.1 Dudley, David
- RE: FW: EPICS 3.15.1 Dudley, David
- Re: FW: EPICS 3.15.1 Michael Davidsaver
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
