1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Area Detector and Andor
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 3 Dec 2014 11:16:16 -0800
Right, that is what I did in the "modified" version of the AD module.
Thanks Mark,
Zen
On 12/03/14 11:09, Mark Rivers wrote:
It sounds like you need to just comment out these lines in ADAndor/andorSupport/Makefile as I have done below:
else ifeq (linux-x86_64, $(findstring linux-x86_64, $(T_A)))
#LIB_INSTALLS_Linux += ../os/linux-x86_64/libandor.so.2
Then these files will not be installed into ADAndor/lib/linux-x86_64
-----Original Message-----
Sent: Wednesday, December 03, 2014 12:59 PM
To: Mark Rivers; [email protected]
Hi Mark,
I need to put a bit more effort into understanding what is going on when
I use AD 2.1.
This is the contents of:
zms@esaanal2 $ ll ADAndor/lib/linux-x86_64/
total 5537
drwxr-xr-x 2 mdunning ar    2048 Nov 22 10:33 ./
drwxr-xr-x 3 mdunning ar    2048 Nov  7 20:41 ../
-r--r--r-- 1 mdunning ar 2645945 Nov  7 20:41 libandor.so
-r--r--r-- 1 mdunning ar 2645945 Nov  7 20:41 libandor.so.2
-r--r--r-- 1 mdunning ar  213304 Nov 22 10:33 libandorCCD.a
-r-xr-xr-x 1 mdunning ar  159262 Nov 22 10:33 libandorCCD.so*
Before building the Andor IOC, I remove both libandor.so and
libandor.so.2.  This works for the case of AD 1.8 and 1.9.1.
Anyway, I will dig a bit deeper into the code to see why the AD 2.1 is
not working for us.
BTW, AD 2.1 works fine with our Prosilica cameras.
Zen
On 12/03/14 10:40, Mark Rivers wrote:
Hi Zen,
One more problem remains.  This fix works with AD 1.8 and 1.9.1 but not
with 2.1.
The IOC built with AD 2.1, still exhibits the same problem, all seems to
work except for getting the image data.  I wonder if there is another
level if mismatch between AD 2.1 and our SDK?
I did not change the Andor linux-x86_64 libraries between 1.8 and 2.1.  They are all 2.84.
I did upgrade to 2.98 for the upcoming 2.2 release.
Commenting out the install in the andorSupport directory is fine.  Alternatively I think you can add a line to your Makefile that tells it where to find the libandor.so file, probably andor_DIR=/usr/local or something.
I cannot explain why it would not work for you with 2.1 since I did not update the library, and in any event you should not be installing the library that comes with ADAndor anyway.
What is the contents of ADAndor/lib/linux-x86_64?
Sent: Wednesday, December 03, 2014 12:20 PM
Subject: Area Detector and Andor
Hi Mark,
I returned to our Andor problem and now I mostly understand what is
going wrong.
It turns out that the libandor.so library which comes with the Area
Detector package does not work with our version of the Andor SDK, which
is version 2.94.  Building Area Detector package puts libandor.so in
lib/linux-86_64, the IOC when built, links to the library in Area
Detector, and when started, loads this library and the IOC almost works
with the exception that no image data are received from the camera.
If I remove the libandor.so library from the Area Detector, build my IOC
it links to the libandor.so library in the locally installed SDK
package.  When I start the IOC it loads the SDK library and everything
works; the image data are received from the camera.
Presently we have AD version 1.8, 1.9.1, and 2.1 installed.  I have
modified a Makefile in the andorSupport directory not to install the
andor libraries.  I am not sure if this is the correct way to deal with
our problem.
with 2.1.
Zen
RE: Area Detector and Andor Mark Rivers
Area Detector and Andor Zenon Szalata
Re: Area Detector and Andor Zenon Szalata
Prev: RE: Area Detector and Andor Mark Rivers
Next: RE: FW: EPICS 3.15.1 Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Area Detector and Andor Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
