1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Gateway 2.0.5.0 released
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 04 Dec 2014 14:57:43 +0100
All,
I just uploaded a minor release of the CA Gateway [1], tagged 2.0.5.0 - featuring
 * 3.15 compatibility: compiles against 3.14.11+ and 3.15.1
* Support for the CaPutLog module to log CA put operations, using the same library as the IOC [2]
   (thanks to FRIB for this contribution)
It seems that Windows builds have been broken for a while - they still are.
If you are in production, I would think the update is of low priority, unless you want to use the CA Put Log support.
Source tar available at https://launchpad.net/epics-gateway/trunk/2.0.5.0/+download/gateway2_0_5_0.tar.gz
Next things in the Gateway pipeline include:
 - Make it a standard self-contained EPICS TOP module
 - Deprecate the built-in watchdog/restart in favor of using procServ [3]
 - Add integration testing (SLAC started working on this)
 - Support DBE_PROPERTY event flag (SLAC started working on this)
 - Resurrect Windows build (volunteers?)
Cheers,
~Ralph
[1] http://launchpad.net/epics-gateway
[2] http://www-csr.bessy.de/control/SoftDist/caPutLog/
[3] http://sourceforge.net/projects/procserv/
CA Gateway 2.0.5.1 released Ralph Lange
RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Prev: RE: FW: EPICS 3.15.1 Mark Rivers
Next: RE: 3.15.1 DB Build Issue Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.15.1 DB Build Issue Ralph Lange
Next: CA Gateway 2.0.5.1 released Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
