Hi Mark and Eric,
Thank you for the advice. I agree it seems that programming my own code for this is the way to go. It turns out if I add a wait command between the in (and corresponding acknowledging out command) I no longer receive the timerQueue error. However, the timing seems to be inconsistent and not always quick enough to allow proper behavior of the device. I removed this wait command as well as polling and it turns out to my surprise that even with the error message the device works well. It seems the polling (when it conflicts with the unsolicited messages) is causing the erratic behavior which apparently is not related to the timerQueue error messages. This is not ideal, but I programmed it such that when I expect the unsolicited commands it no longer polls the device. (The user initiates the device and then it begins sending the unsolicited commands so we kind of know when to not poll the device). Thanks again for the help. -Andrew On Mon, Jan 5, 2015 at 1:22 PM, Mark Rivers <[email protected]> wrote:
ANJ, 16 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
