hi, On the website of
EPICS Sequencer Home, there are several examples about SNL which use exit in
two places. The first one is
in the example "Entry and exit action example" ,that exit part will
execute one time when the state changes from high to low. and, if use "option -e" switch, the entry will be
executed each time, not as expected. Without "option -e" switch, it
will run as the document's behavior, did I make some mistake? The second one is
in the “Complex example “ (http://www-csr.bessy.de/control/SoftDist/sequencer/Examples.html#exit-procedure) Exit is a separate
part out of state set, I am wondering when that exit procedure will be
executed? Thanks a lot for
your help. Best wishes
Geyang 2015-01-12
| ANJ, 16 Dec 2015 |
· Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
