1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor record SYNC using URIP = 1
Date: Wed, 21 Jan 2015 19:26:52 +0000
     I have some motors using URIP = 1 that, after IOC boot and caput on
STUP = 1, get the correct value in RBV field, according to the PV
configured in RDBL and RRES resolution. But I suppose that VAL field
took a value based on motor driver counter and MRES.  I tried to do
caput on SYNC field to get RBV value to VAL but it happened to work at
the opposite way - VAL value went to RBV.
     I checked the motorRecord.cc file and I think the URIP = 1 case was
not defined there. If I'm using it in the wrong way, please point me
what is it. Otherwise I'd like to propose a modification in function
syncTargetPosition(motorRecord *pmr) of motorRecord.cc file. See it
below, please:
*** motorApp/MotorSrc/motorRecord.cc    2015-01-21 16:55:51.000000000 -0200
--- motorApp/MotorSrc/motorRecord.last.cc    2015-01-21
17:07:54.000000000 -0200
*************** static void syncTargetPosition(motorReco
*** 4035,4041 ****
           pmr->rrbv = pmr->rep;
           pmr->drbv = pmr->rrbv * pmr->eres;
!     else if (!pmr->urip)
           pmr->rrbv = pmr->rmp;
           pmr->drbv = pmr->rrbv * pmr->mres;
--- 4035,4041 ----
!     else if
     I added "if (!pmr->urip)" on the else case.
     I tested it and SYNC worked pretty fine in my case. I'm using motor
record 6-8 but I saw that 6-9 has the same code for the sync function.
     Thank you for your attention,
Márcio Paduan Donadio
Computer Engineer - LNLS
Prev: RE: related to driver Mark Rivers
Next: EPICS driver for CAENels HV-Adaptos? nicoletta.de-maio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
