1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building epics base under CentOS 5.6
To: GONG Yu <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 27 Jan 2015 10:33:41 -0600
Hi Gongyu,
On 01/27/2015 09:24 AM, GONG Yu wrote:
>      During builing of EPICS base in this time, there is no errors that I came accross last time. It is likely that I missed the libstdc++-devel components in the installing of g++ last time.
>      The last several lines goes like these:
> mkdir ../../../lib/perl/5.8.8
> mkdir ../../../lib/perl/5.8.8/i386-linux-thread-multi
> Installing script ../../../bin/linux-x86/cainfo.pl
> Installing script ../../../bin/linux-x86/caput.pl
> Installing script ../../../bin/linux-x86/caget.pl
> Installing script ../../../bin/linux-x86/capr.pl
> Installing script ../../../bin/linux-x86/camonitor.pl
> rm -f CA.html
> podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
> ../CA.pm pod syntax OK.
> Installing html ../../../html/./CA.html
> rm CA.html
> make[3]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src/cap5/O.linux-x86'
> make[2]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src/cap5'
> make[1]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src'
>      I wonder if the building of EPICS base succeeds.
Yes, those are the last lines you should see after a successful build of
3.14.12.4. If you want to you can run the built-in self-tests as well by
typing 'make runtests' at the top of the build tree, but this is optional.
>      Following your suggestion, here I build the EPICS base-3.14.12.4, besides,
>      base-3.14.12 (which is also built for test) gives these similar
results.
If you can use the newer version I would recommend that as it has some
known bugs fixed.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
Problem building epics base under CentOS 5.6 GONG Yu
Re: Problem building epics base under CentOS 5.6 Andrew Johnson
Re: Re: Problem building epics base under CentOS 5.6 GONG Yu
Prev: Re: Re: Problem building epics base under CentOS 5.6 GONG Yu
Next: RE: caQtDM Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Checking which record triggered processing Tobiasz Czopowicz
