What happens if you just run 'make' without the 'sudo' (which you should not be using, Base does not need to be built as root)?
Are you building an old version of Base for any specific reason? The latest version is 3.14.12.4 and contains various advances and bug fixes since 3.14.11. The Channel Access network protocol is compatible across different versions.
- Andrew
Sent from my iPad
> On Jan 27, 2015, at 11:26 PM, Rahul Jain <[email protected]> wrote:
> Hello
> I am trying to build EPICS base 3.14.11 on linux-x86 (32 bit) but when I
> run sudo make command, I get following error:
> confiugure/CONFIG:55: configure/os/CONFIG.unsupported.Common: No such file
> or directory
> *** No rule to make target 'configure/os/ CONFIG.unsupported.Common'. Stop
> I have used following configuration set up for crosscompiling EPICS
> Set up of configure/CONFIG_SITE script
> CROSS_COMPILER_TARGET_ARCHS=linux-arm
> CROSS_COMPILER_HOST_ARCHS=linux-x86
> SHARED_LIBRARIES=NO
> STATIC_BUILD=YES
> Our cross-compiling toolchain is in $HOME/local/x-tools/arm-unknown-linux
> gnueabi, so I used following configuration:-
> Set up of configure/os/CONFIG_SITE.linux-x86.linux-arm
> GNU_DIR = $HOME/local/x-tools/arm-unknown-linux gnueabi
> GNU_TARGET = arm-unknown-linux gnueabi
> I have also tried setting up EPICS_HOST_ARCH environment variable
> seperately by using following command:
> export EPICS_HOST_ARCH=linux-x86
> I am still getting same error message, Please solve my above query.
> Thanks
> Rahul Jain
- Re: Problem in building EPICS Rahul Jain
RE: caQtDM Mark S. Engbretson
Issues with installing the adPython plugin for areaDetector David Michel
<2015>
RE: caQtDM Zai Wang
<2015>
