Hi Lewis,
On 01/30/2015 05:25 PM, J. Lewis Muir wrote:
> I'm trying to build EPICS Base 3.14.12.4 (with the Known Problems
> patches applied) for win32-x86 on Windows 7 using Microsoft Visual C++
> 6 (yes, a very old compiler). The build doesn't get very far before
> failing with the following output:
> Obviously, it seems to be unhappy with the "delete" on line 93 of
> epicsRingPointer.h, but I don't know how to fix it.
I don't think you'll be able to, MS Visual C++ 6 was released in 1998
(17 years ago, long before MS implemented standard C++) and it doesn't
support all of the C++ constructs that we make use of in Base. In 2008
Jeff Hill explained that VC7 was too old to build Base-3.14.9:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00078.php
Can't you upgrade the compiler?
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
against your wishes, and doesn't give you the key, they're
not doing it for your benefit.
- Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
- epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
related to coding priya tiwari
<2015>
2025
<2015>
2025
