If I understood the documentation properly, than this is actually working as expected; excerpt from pvData[1] docs:
postPut
If a postHandler is registered it is called otherwise no action is taken.
NOTE: The implementation of the various data interfaces automatically call postPut when a field is changed. However this is not true for a subField of a PVUnion, PVUnionArray, or PVStructureArray. If a subField of any of these is changed then the code that is making the modification must call postPut for the PVUnion, PVUnionArray, or PVStructureArray field. Note also that it is not a good idea to modify a subfield of a PVUnionArray or a PVStructureArray since it violates the idea of Copy On Write for arrays
Cheers, Tom
[1] http://epics-pvdata.sourceforge.net/docbuild/pvDataCPP/4.4.0/documentation/pvDataCPP.html
Tom SLEJKO, Senior Control system engineer
Email: [email protected]
http://www.cosylab.com Phone: +386 (40) 349-082
Teslova ulica 30
Skype: tomslejko
----- Original Message -----
To: [email protected]
Sent: Friday, 6 February, 2015 9:04:58 PM
Subject: V4 pvDatabase PVRecord bug?
Hi everyone,
I am doing some experiments with v4. I have a simple v4 IOC with a single NTNDArray record. On the client side I'm just monitoring it with pvget -m.
Everything works fine as I put new values on different fields of my record, except for the 'value' field, which is a union. If I put a new value there (select, reuse, copy data, replace) the monitor doesn't pick up the change. Other fields update automatically after put(). I can fix this by calling the method postPut on the field.
Is this the way it's supposed to be?
I'm using the latest version of everything from the mercurial repos.
Thanks!
Bruno
- V4 pvDatabase PVRecord bug? Bruno Martins
Re: Fetching return value from external program call in StreamDevice Torsten Bögershausen
How to make standalone applications run from within EPICS shell Deeptarka Das/TVM/TCS
<2015>
epics on ios Mezger Anton Christian (PSI)
<2015>
