1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: medm3.1.8 linker problem
To: [email protected]
Date: Tue, 10 Feb 2015 19:26:46 +0100
On February 10, 2015 6:11:56 PM GMT+01:00, Bob Soliday <[email protected]> wrote:
I just tried building this on ubuntu 14.04 and got it to build by changing the default values for MOTIF_LIB and X11_LIB. Try building it with:
make MOTIF_LIB=/usr/lib/x86_64-linux-gnu X11_LIB=/usr/lib/x86_64-linux-gnu
On 02/08/2015 11:27 AM, yann stephen wrote:
good day!
i am trying to install medm3_1_8 / medm3_1_9 on ubuntu 14.04  after successfully installing baseR3.14.12.4.
when i try to make medm i receive this error.
/usr/bin/ld: /usr/lib/libXt.a(Shell.o): undefined reference to symbol 'SmcInteractDone'
//usr/lib/i386-linux-gnu/libSM.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[2]: *** [medm] Error 1
make[2]: Leaving directory `/opt/epics/extensions/src/medm3_1_8/medm/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_8/medm'
make: *** [medm.install] Error 2
i dont really know what to do here,
thanks inadvance for helping.
steve
Careful:
Try not to mix architectures. Stephen was building for 32bit, so i386-linux-gnu would be the right path part in multi-arch setups.
~Ralph
medm3.1.8 linker problem yann stephen
Re: medm3.1.8 linker problem Bob Soliday
Prev: finding "lost" IOCs Michael Davidsaver
Next: Re: CA Repeater: bind test err was "The operation completed successfully. " Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: medm3.1.8 linker problem Bob Soliday
Next: How to make standalone applications run from within EPICS shell Deeptarka Das/TVM/TCS
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
