I think you need the package called libpng12-0
From: [email protected] [[email protected]] on behalf of Rahul Jain [[email protected]]
Sent: Tuesday, February 17, 2015 10:15 PM
To: [email protected]
Subject: Error in EDM-1-12-98 installation
Hello,
I am facing problem in installing edm-1-12-98, although I have already
installed the following libraries required for EDM installation on my
linux-x86 (ubuntu 14.04) PC.
libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3, libungif-4.1.3,
libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
libxmu-headers, libxp-dev, libxmu-dev, libxmu6
The error messages, while installing edm-1-12-98 is given as follows:-
/usr/bin/g++ -o edm -L/opt/myepics/base-3.14.12.4/lib/linux-x86
-L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
-L/usr/lib/i386-linux-gnu
-Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
-Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
-Wl,-rpath,/usr/lib/i386-linux-gnu -m32 -z combreloc -z lazyload
main.o -lcfcaa62e-8199-11d3-a77f-00104b8742df
-l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst -lX11
-lca -lCom -lpthread -ldl
/usr/bin/ld: warning: -z lazyload ignored.
/usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
/usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
`png_set_filler@PNG12_0'
`png_set_packing@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_update_info@PNG12_0'
`png_set_interlace_handling@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_read_struct@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
`png_get_io_ptr@PNG12_0'
`png_set_palette_to_rgb@PNG12_0'
`png_get_error_ptr@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
`png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined reference
to `png_read_end@PNG12_0'
`png_error@PNG12_0'
`png_set_read_user_transform_fn@PNG12_0'
`png_set_read_fn@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_info_struct@PNG12_0'
`png_set_expand_gray_1_2_4_to_8@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
`png_set_tRNS_to_alpha@PNG12_0'
collect2: error: ld returned 1 exit status
make[2]: *** [edm] Error 1
make[2]: Leaving directory
`/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain' make:
*** [edmMain.install] Error 2
Please suggest me, how to fix this error message.
Regards
Rahul Jain
- Error in EDM-1-12-98 installation Rahul Jain
Re: Error in EDM-1-12-98 installation Mike Westfall
<2015>
<2015>
