Thank you. One more question. I am EPICS driver developer. Is there any way in the asynDriver where i can set this in my driver so that even application developer forget to set asynSetTraceMask in the application st.cmd, these error message can be stopped by driver? Thank you Vishnu From: Mark Rivers <[email protected]> Sent: Wed, 04 Mar 2015 01:56:01 To: 'Vishnu Patel' <[email protected]>, "techtalk " <[email protected]> Subject: Re: error on the IOC shell for asyn driver Hi Vishnu, Type the following command at the iocsh prompt, or include it in your startup script if you know the port will not be connected: asynSetTraceMask <port name> 0 0 Mark From: [email protected] [mailto:[email protected]]
On Behalf Of Vishnu Patel
In my asyn based driver while the port is not connected all the scanning records are throwing an errors <PV NAME> devAsynInt32 queueRequest port <port name> not connected it is same for all asyn interfaces. How i can stop error messages on the IOC shell while port is not connected? Thank you Vishnu
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
