1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: related to array
Date: Wed, 11 Mar 2015 14:18:08 +0530
I have used compress record, now it is working.......
On Tue, Mar 10, 2015 at 6:35 PM, Mooney, Tim M. <[email protected]> wrote:
You can also do this with the sscan record.
http://www.aps.anl.gov/bcda/synApps/sscan/sscanRecord.html
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Tuesday, March 10, 2015 5:58 AM
To: priya tiwari; [email protected]
Subject: RE: related to array
One way I think you can do this is to use the acalcout record:
http://www.aps.anl.gov/bcda/synApps/calc/aCalcoutRecord.html
From: [email protected] [[email protected]] on behalf of priya tiwari [[email protected]]
Sent: Tuesday, March 10, 2015 12:05 AM
To: [email protected]
Subject: related to array
Hello sir,
       I am plotting a graph between current and voltage.Here User set the current and read a corresponding voltage from device upto 20 times.Here we are reading one value of current and its corresponding voltage and transfer this value into waveform record.Here I am taking two waveform records one for current and another for voltage.The value is stored on 0th index of waveform.In the next iteration change the value of current and again send to waveform then again value is putting on 0th index but I want to put on 1st index then in next iteration ,put on 2nd index of waveform.How to previous values stored in array?
2. Now the problem is occurring ,in case of plot always I get one point and previous did not store. I want to store all values and draw the graph from point 1 to 20.
      How to solve this problem?please provide me solution of this problem...
                                 Thanks in advance...
related to array priya tiwari
RE: related to array Mark Rivers
RE: related to array Mooney, Tim M.
Prev: RE: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Next: VDCT for Windows ? Amit Chauhan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: related to array Mooney, Tim M.
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
