1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Text input to char waveform - bug?
To: [email protected]
Date: Wed, 18 Mar 2015 12:12:22 +0000
Hi All,
I'm running CSS 3.2.16 in Windows.
I have a BOY text input widget that I want to use to write to a waveform of char, called TEST.
The waveform is empty at startup.
If I type something in the text input, like "abc", I get the following error message in the BOY Console:
2015-03-18 12:04:37 ERROR: Failed to write value to PV TEST from widget Text Input_1.
Illegal input : abc
java.lang.ArrayIndexOutOfBoundsException: 0
If the waveform is not empty, the string gets updated correctly and there is no error.
If I do the same in CSS in my Linux VM, all works fine, even at startup.
Is this a bug in the Windows version or am I missing something?
Isabella
Re: Text input to char waveform - bug? Hinko Kocevar
Prev: Re: related to PLC driver Mike Westfall
Next: Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? - SOLVED Isabella Rey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Text input to char waveform - bug? Hinko Kocevar
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
