1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: related to controls in edm
Date: Fri, 27 Mar 2015 11:56:38 +0530
Hello sir,
I am beginner in EDM and I want to add a button in EDM. When I will press the button then my progam should be start otherwise should not be start. In case of my program, I am going  from 10 mA(i.e. initial value in current source)  to 120 mA(i.e. final value) with step of 10.How to use message button which act as a START button of my program and this should be press(toggle) only one time and program should be proceed and also I want to add stop button so that when press stop then whole program should be stop.How to perform this task ,I have no idea because for loop or while loop does not work in VDCT directly. Please provide example for this type of task.
Thanks in advance......
RE: related to controls in edm Mooney, Tim M.
Prev: RE: Registration Open for the Spring 2015 EPICS Collaboration Meeting Williams Jr., Ernest L.
Next: Re: Record issue - to set aother record value Amien Crombie [TLABS]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Text input to char waveform - bug? - Maybe SOLVED Isabella Rey
Next: RE: related to controls in edm Mooney, Tim M.
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
