Hi William
Thanks for the bug report.
After pondering the code for a while I have come to the conclusion that
the assertion is indeed wrong. The assumption was that the dbr field of
the event_handler_args struct that is passed to an event handler can
only be NULL if the request was a put request. Apparently this is wrong:
when connection to a PV is lost while a get request is pending, the
handler will be called with a NULL dbr field, too.
I will make a patch that removes the assertion.
Cheers
Ben
On Tuesday 31 March 2015 17:55:18 William F. Steele wrote:
> Hello Benjamin,
> Following the instructions, I’m sending this error message to you
> which popped up while starting the undulator control system here at
> Lawrence Berkeley Lab’s Advanced Light Source:
> CA.Client.Exception...............................................
> Warning: "Virtual circuit unresponsive"
> Context: "ffbsec04.als.lbl.gov:5064"
> Source File: ../tcpiiu.cpp line 945
> Current Time: Tue Mar 31 2015 15:56:01.345016461
> A call to 'assert((value==NULL)==(evtype == pvEventPut))'
> by thread 'timerQueue' failed in ../seq_ca.c line 282.
> EPICS Release EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$.
> Local time is 2015-03-31 15:56:01.349364576 PDT
> Please E-mail this message to [email protected] or
> to [email protected] Calling epicsThreadSuspendSelf()
> 31Mar 15:56:41 FF04-2 Resetting: Errors during reset: 5 total
> Unexpected problem with CA circuit to server
> "ffbsec04.als.lbl.gov:5064" was "Connection reset by peer" -
> disconnecting 31Mar 15:56:51 FF04-2 Resetting: Connect count !=
> Channel count Connect count = 104, Channel count = 105
> Up ’til now I had been using seq-2.1.16. I just switched to seq-2.2.1.
> I am running 8 soft IOCs (on 2 PowerPMAC controllers running Linux,
> EPICS 3.14.12.4) each running an instance of the same sequencer
> program. I saw this assertion on only one of the sequencer instances.
> It occurred when a computer, to which the sequencer had a CA
> connection, was rebooted (all of the computers to which all of the
> sequencers had connections were rebooted during our startup
> procedure). The soft IOC was not able to recover on its own, but
> restarting the did clear the problem.
> Thanks,
> William Steele
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
<2015>
2025
STAT=SCAN recover Isabella Rey
<2015>
2025
