Hi Dirk, Thanks for the file. I have replaced it in the StreamDevice src directory, but when I ran make it gave me this error: ../StreamEpics.cc: In static member function ‘static long int Stream::report(int)’: ../StreamEpics.cc:356:26: error: ‘class Stream’ has no member named ‘printStatus’ make[2]: *** [StreamEpics.o] Error 1 I tried commenting out the line 356, and got no error - Should I just remove the line, or do I need to update StreamCore? I am running on StreamDevice 2.6 Apart from that, with the line 356 commented out, I've changed the protocol to use %s and I don't get the null character anymore. :) Cheers, Isabella On 2 April 2015 at 14:03, Dirk Zimoch <[email protected]> wrote: Here is the bug fix.
ANJ, 16 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
