Sorry, the glib paths are actually defined in EXAMPLE_CONFIG_SITE.local.linux-x86_64.
Sent from my iPhone
> On Apr 7, 2015, at 10:26 AM, Mark Rivers <[email protected]> wrote:
> What version of the top-level areaDetector and aravisGigE are you using? The latest version defines paths for glib in areaDetector/configure/EXAMPLE_CONFIG_SITE.local
> The message about .a vs.so is just because it did not find either one.
> Mark
> Sent from my iPhone
> On Apr 7, 2015, at 9:30 AM, Mazanec Tomáš <[email protected]<mailto:[email protected]>> wrote:
> I don't have synApps 5.8, however in standalone "aravisGigE-0-1-15dls2", there is GLIBPREFIX option in configure/RELEASE,
> then aravisGigEApp/src/Makefile defines USR_INCLUDES and USR_LIBS based on that.
> I guess , try to match these with your RHEL.
> Other option is to use USR_SYS_LIBS+=glib-2.0 instead.
> By default, linker should accept both library formats (.so , .a).
> Tomas
> ________________________________
> Od: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] za uživatele Specht, Eliot D. [[email protected]<mailto:[email protected]>]
> Odesláno: 7. dubna 2015 15:39
> Komu: [email protected]<mailto:[email protected]>
> Předmět: aravisGigEApp and glib
> I’m trying to use aravisGigEApp on a RHEL7 linux system to display and capture video images. When I run “make” in aravisGigEApp/src, I get an error which looks like I’m missing libglib-2.0.a (see below). I have /usr/lib64/libglib-2.0.so, but I seem to need the glib2-static package, which is not available for RHEL7. Is there a fix for this, or should I fall back to RHEL6?
> [root@video src]# make
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> make[1]: Entering directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
> make[1]: *** No rule to make target `../../../lib/linux-x86_64/libglib-2.0.a', needed by `libaravisCamera.so'. Stop.
> make[1]: Leaving directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
> make: *** [install.linux-x86_64] Error 2
> [root@video src]#
> Eliot Specht Voice: (865)574-7682
> Oak Ridge National Laboratory FAX: (865)574-4913
> P.O. Box 2008, MS 6064
> Oak Ridge, TN 37831-6064
- aravisGigEApp and glib Specht, Eliot D.
- RE: aravisGigEApp and glib Mazanec Tomáš
- Re: aravisGigEApp and glib Mark Rivers
send a file to IOC [email protected]
<2015>
<2015>
