1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: send a file to IOC
To: [email protected]
Date: Tue, 7 Apr 2015 21:11:28 +0200 (CEST)
ok,
thanks a lot for your suggestions and links;
I'm starting to study this solution;
Gennaro
On Tue, 7 Apr 2015, Andrew Johnson wrote:
On 04/07/2015 12:22 PM, [email protected] wrote:
I'm developing a run control / slow control system with EPICS
and a feature of this system is FPGA reprogramming by XSVF file;
is it possible to define a PV (or something else) in order to
receive a binary file sent by remote (e.g. by CSS) ?
Eric Norum developed something like that for programming flash memory
chips through CA when he was working here at the APS. The IOC it ran on
didn't have a lot of RAM, so it comes with a CA client program that
writes the data file (in this case it expects S-record format) to a
waveform record on the IOC one flash page at a time. On the IOC side the
code is an Asyn Octet driver.
You can find the code for it in the mcf5282 module here:
 http://www.aps.anl.gov/epics/modules/instrument/mcf5282/index.html
Note that there is other stuff in this module which will not be relevant
to you, but studying the files in mcf5282Sup/src with flash in their
name might give you a good starting point. Send questions here.
- Andrew
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
"Computer Science is no more about computers
    than astronomy is about telescopes."
    - Edsger Dijkstra
send a file to IOC [email protected]
Re: send a file to IOC Andrew Johnson
Prev: Re: send a file to IOC Andrew Johnson
Next: RE: send a file to IOC austen.rose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
