1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS Boy and Signed/Unsigned Int Issue
To: <[email protected]>
Date: Wed, 8 Apr 2015 11:01:46 +0000
Hi all,
I am having a problem with a camera that uses unsigned 8-bit integers for its values, which get interpreted as -127 --> 128 instead of 0 --> 255 in CSS BOY.
I saw on a previous discussion there was a suggested workaround (http://www.aps.anl.gov/epics/tech-talk/2014/msg00510.php), but this does not work for me due to some auto-normalisation scripts we are using, and this would also prevent choosing color maps.
I was just wondering if anyone had found a better solution to the issue? Trying to use a Python script to correct the values seems to be extremely slow.
Ian
RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
Prev: StreaDevice formating problem Jörn Wüstenfeld
Next: Re: StreaDevice formating problem Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreaDevice formating problem Jörn Wüstenfeld
Next: RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
