1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits
To: "[email protected] ([email protected])" <[email protected]>
Date: Wed, 8 Apr 2015 21:34:08 +0200
Hi folks,
is there an easy way to prevent the clipping within limits (DRVH, DVL) in the analog output record (softChannel).
I would like to simply ignore a value that lies outside the limits without using an addtional record (e.g. calcout)
to check the value beforehand.
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Andrew Johnson
Prev: Re: StreaDevice formating problem Jennings, Guy
Next: Re: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS Boy and Signed/Unsigned Int Issue ian.bush
