1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: StreamDevice reading waveforms
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Mon, 13 Apr 2015 07:59:47 -0500
Hi Dirk,
Thank you for your reply. Unfortunately, there are many more than three rows to read, up to 256k samples/channel. I used a value of three for my debugging.
One suggestion I received was to read everything into one huge array and use an asub record to parse the values.
Tony
On Apr 13, 2015, at 3:54 AM, Dirk Zimoch <[email protected]> wrote:
Hello Anthony,
For waveform records StreamDevice repeats the format for each element and optionally reads a separator in between. While this allows to read a row, it cannot read a column. And it probably does not work with redirection (I have never tried).
This makes it a bit complicated to read your device. But hopefully not impossible. You need a few more records.
I understand that the reply always consists of 3 rows. Then I would try the following:
Have two longin records, one for X and one for X.
Redirect to these records as you do now, but do it 3 times:
Terminator = "\n";
getTBT_XY {
   out "TBT_XY 3";
   in   " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d";
This processes the two longin records 3 time each. For the waveforms use two compress records and do a FLNK from the longin records to the compress records:
record (longin, "$(P)$(R)TBT_Horizontal_tmp")
  field (FNLK, "$(P)$(R)TBT_Horizontal")
record (compress, "$(P)$(R)TBT_Horizontal")
  field (INP,"$(P)$(R)TBT_Horizontal_tmp")
  field (ALG, "Circular Buffer")
  field (NSAM,"3")
The same for Vertical.
I am not quire sure about the compress record settings. Maybe you need to try a bit.
Maybe you may want to write to the .RES of the compress before starting. In that case you can use additional seq records.
Hope this helps.
Dirk
On 09.04.2015 23:01, Anthony Pietryla wrote:
I have a device which uses SCPI protocol and returns sets of waveforms
in columns where I can request how many rows to return. For instance I
can query the device for 3 values of position data and it will return 2
columns (X & Y) and 3 rows. I want to read the columns into separate
waveform records. I am having problems with the protocol file for which
I need help.
The database records and the protocol file are listed below. When I
process the record only the first values (first row of data) are written
to each record. With asyn debugging turned on the console shows all
three sets of data:
epics> 2015/04/09 13:52:36.877 L0 wrote
TBT_XY 3
2015/04/09 13:52:36.878 L0 read
  2000   6000
  7143   4286
  4286   1429
caget shows only the first value stored:
caget -# 5 B:Spark:TBT_Horizontal
B:Spark:TBT_Horizontal 5 3333 0 0 0 0
caget -# 5 B:Spark:TBT_Vertical
B:Spark:TBT_Vertical 5 -1111 -3333 0 0 0
The protocol file has:
getTBT_XY {
   Separator = "\n";
   out "TBT_XY 3";
   in   " %(\$1TBT_Horizontal)d %(\$1TBT_Vertical)d";
   ExtraInput = Ignore;
The database records are:
record(waveform, "$(P)$(R)TBT_Horizontal")
   field(DESC, "TBT Horizontal")
   field(DTYP, "stream")
   field(INP,  "@spark.proto getTBT_XY($(P)$(R)) $(PORT)")
   field(NELM, "262144")
   field(EGU,  "um")
   field(FTVL, "LONG")
record(waveform, "$(P)$(R)TBT_Vertical")
   field(DESC, "TBT Vertical")
   field(DTYP, "Soft Channel")
   field(EGU,  "um")
   field(FTVL, "LONG")
When I comment out the “ExtraInput = Ignore;” line in the protocol file
I get error messages:
2015/04/09 15:53:58.170 L0 wrote
TBT_XY 3
2015/04/09 15:53:58.170 L0 asynOctetBase interrupt
2015/04/09 15:53:58.171 L0 read
  3333  -1111
 -3333  -5556
 -2000      0
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: 29 bytes surplus
input "<0a> -3333  -5556<0a> -200..."
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: after 13 bytes:
"  3333  -1111"
Anthony Pietryla
Principal Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
Anthony Pietryla
Phone: 630-252-7430
Fax: 630-252-6123
Re: StreamDevice reading waveforms Dirk Zimoch
StreamDevice reading waveforms Anthony Pietryla
Prev: Re: StreamDevice reading waveforms Anthony Pietryla
Next: Re: StreamDevice reading waveforms Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: StreamDevice reading waveforms Dirk Zimoch
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
