1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Help-areaDetector used for Pilatus
To: EPICS_tech_talk <[email protected]>
Date: Fri, 17 Apr 2015 10:49:39 +0800 (GMT+08:00)
Hello everyone,
  Recently I use areaDetector to control pilatus3 detector, but I am not sure if the parameters in st.cmd were set correctly. In st.cmd scripts,
**question1:  epicsEnvSet("QSIZE",  "20")
  what does QSIZE mean? What number should I set to it or just using default 20?
**question2:  epicsEnvSet("NCHANS", "2048")
  what does NCHANS mean? What number should I set to it or just using default 2048?
  in areaDetector.adl main screen, I also have a problem:
**question3: when I exposure single image, namely the parameters [# Images] 1, [Auto increment] Yes, I press [sta  rt] the [Next file #] (shown in blue color beside the box) is auto incremented which is as I expected; But if I  set [#Images] 10 and [Auto increment] Yes to exposure multy images, after I press [start], the numbers followed  the file name in name of image files are correct (such as from 000 to 009), but the [Next file#] (shown in blue  color beside the box) is auto incremented only once (such as from 000 to 001, but not incremented anymore). Is   this situation abnormal ?
**Some parameters related to Pilatus3 is as below
  number of modules                 3x8=24
  pixel size                        172x172   μm^2
  format                            1475x1679=2476525  pixels
  Dynamic range                     20        Bits (0: 1048573)
  Counter overflow state            1048573
  readout time                      0.95      ms
  Framming rate                     250       Hz
  (camserver is in a computer with IP 10.10.10.100, areaDetector is in another computer with IP 10.10.10.10.)
**The contents in st.cmd are listed below
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/pilatusDetectorApp.dbd")
pilatusDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "13PIL1:")
epicsEnvSet("PORT",   "PIL")
epicsEnvSet("XSIZE",  "1475")
epicsEnvSet("YSIZE",  "1679")
# Create the asyn port to talk to the Pilatus on port 41234.
drvAsynIPPortConfigure("camserver","10.10.10.100:41234")
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
asynOctetSetOutputEos("camserver", 0, "\n")
pilatusDetectorConfig("$(PORT)", "camserver", $(XSIZE), $(YSIZE), 0, 0)
dbLoadRecords("$(ADCORE)/db/ADBase.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(ADCORE)/db/NDFile.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(ADPILATUS)/db/pilatus.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "$(PORT)", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDPluginBase.template","P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0")
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=2476525")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd
set_requestfile_path("$(ADPILATUS)/pilatusApp/Db")
#asynSetTraceMask("$(PORT)",0,255)
#asynSetTraceMask("$(PORT)",0,3)
iocInit()
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=$(PREFIX)")
I hope someone could help me. Thank you!
GongYu
RE: Help-areaDetector used for Pilatus Mark Rivers
Prev: New releases of areaDetector modules ADPixirad, ADPointGrey, ADProsilica, ADPvCam Mark Rivers
Next: RE: Help-areaDetector used for Pilatus Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
