1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: iocStats reboot question
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 17 Apr 2015 10:44:36 +0200
Hi Geyang,
Under Linux (and the other host-type OSs), an IOC is a single multi-threaded process.
So, naturally, "rebooting" an IOC means restarting the IOC process, which is usually done by shutting down or killing the current process and letting the wrapper (e.g. procServ) handle the restart.
Very often, many Linux IOCs are run on a single host: 20-30 are quite common, I have seen up >300 IOCs on a server-class Solaris machine.
I am sure you understand that allowing to reboot the server from any of these IOCs would be a bad idea.
Also, rebooting a server usually needs root access. IOCs should not be run as root.
Cheers,
~Ralph
On 17/04/2015 09:36, Silver wrote:
hi,
in IOC Status and Control (devIocStats), it has an reboot function in subroutine record, that is ,in devIocStatsSub.c file, it calls reboot function of linux.
I am wandering why this call just kill the ioc process instead of rebooting the machine? as in manual of reboot function (http://man7.org/linux/man-pages/man2/reboot.2.html)
Thanks a lot for your help.
Best wishes
Geyang 2015-04-17
Re: Re: iocStats reboot question Silver
Prev: iocStats reboot question Silver
Next: RE: Gentec S-link power meter problem with ending I/O interrupt measurement bohmm
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Re: iocStats reboot question Silver
