Hi Li,
The problem is this line:
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db","P=xxx:,S=scan1,...
It defines a scaler record named xxx:scan1, but this command:
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/sscan-2-7/sscanApp/Db/scan.db","P=xxx:,MAXPTS1=8000,...
already defined a sscan record with that name. (The database scan.db
contains several scan records, named $(P)scan1, $(P)scan2, etc.)
I suggest you modify that first command to look like this:
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db","P=xxx:,S=scaler1,...
Tim Mooney ( [email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Hi tech-talk,
Could you please do me an offer again. I just want to move a motor then triger a detector, on and on.
I successfully controled the motor and scaler 974 respectively with xxx/iocBoot/iocLinux st.cmd.
But when I put the motor and scaler 974 together, something wrong.
I added the motor and std part of xxx/iocBoot/iocLinux st.cmd myself, others not changed.
After reading the information of st.cmd, I think the &(P)$(S) of record is the question. The detail is: I use the macro value P=xxx:,S=scan1,N=1 for both sscan module(scan.db) and std module(scaler 974).
So the st.cmd said :"Record xxx:scan1 already defined with different type sscan".
Could you tell me how should I do it?
Li Xing
the following is st.cmd information and scan.db. (between "####" and "#####" is what I changed )
st.cmd information
# Linux startup script
# For devIocStats
epicsEnvSet("ENGINEER","engineer")
epicsEnvSet("LOCATION","location")
# add myself
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/bsrf-non/Documents/KohzuAries/db"
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocLinux")
epicsEnvSet("TOP","/home/bsrf-non/Documents/synApps_5_6/support/xxx-5-6")
epicsEnvSet("SUPPORT","/home/bsrf-non/Documents/synApps_5_6/support")
epicsEnvSet("ALLEN_BRADLEY","/home/bsrf-non/Documents/synApps_5_6/support/allenBradley-2-2")
epicsEnvSet("AREA_DETECTOR","/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1")
epicsEnvSet("ASYN","/home/bsrf-non/Documents/synApps_5_6/support/asyn-4-18")
epicsEnvSet("AUTOSAVE","/home/bsrf-non/Documents/synApps_5_6/support/autosave-4-8")
epicsEnvSet("BUSY","/home/bsrf-non/Documents/synApps_5_6/support/busy-1-4")
epicsEnvSet("CALC","/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9")
epicsEnvSet("CAMAC","/home/bsrf-non/Documents/synApps_5_6/support/camac-2-7")
epicsEnvSet("DAC128V","/home/bsrf-non/Documents/synApps_5_6/support/dac128V-2-7")
epicsEnvSet("DELAYGEN","/home/bsrf-non/Documents/synApps_5_6/support/delaygen-1-0-7")
epicsEnvSet("DEVIOCSTATS","/home/bsrf-non/Documents/synApps_5_6/support/devIocStats-3-1-7")
epicsEnvSet("DXP","/home/bsrf-non/Documents/synApps_5_6/support/dxp-3-1")
epicsEnvSet("IP","/home/bsrf-non/Documents/synApps_5_6/support/ip-2-13")
epicsEnvSet("IP330","/home/bsrf-non/Documents/synApps_5_6/support/ip330-2-7")
epicsEnvSet("IPAC","/home/bsrf-non/Documents/synApps_5_6/support/ipac-2-11")
epicsEnvSet("IPUNIDIG","/home/bsrf-non/Documents/synApps_5_6/support/ipUnidig-2-9")
epicsEnvSet("LOVE","/home/bsrf-non/Documents/synApps_5_6/support/love-3-2-5")
epicsEnvSet("MCA","/home/bsrf-non/Documents/synApps_5_6/support/mca-7-1")
epicsEnvSet("MODBUS","/home/bsrf-non/Documents/synApps_5_6/support/modbus-2-3")
epicsEnvSet("MOTOR","/home/bsrf-non/Documents/synApps_5_6/support/motor-6-7")
epicsEnvSet("OPTICS","/home/bsrf-non/Documents/synApps_5_6/support/optics-2-8-1")
epicsEnvSet("QUADEM","/home/bsrf-non/Documents/synApps_5_6/support/quadEM-2-6")
epicsEnvSet("SNCSEQ","/home/bsrf-non/Documents/synApps_5_6/support/seq-2-1-3")
epicsEnvSet("SOFTGLUE","/home/bsrf-non/Documents/synApps_5_6/support/softGlue-2-2")
epicsEnvSet("SSCAN","/home/bsrf-non/Documents/synApps_5_6/support/sscan-2-7")
epicsEnvSet("STD","/home/bsrf-non/Documents/synApps_5_6/support/std-3-1")
epicsEnvSet("STREAM","/home/bsrf-non/Documents/synApps_5_6/support/stream-2-5-1")
epicsEnvSet("VAC","/home/bsrf-non/Documents/synApps_5_6/support/vac-1-4")
epicsEnvSet("VME","/home/bsrf-non/Documents/synApps_5_6/support/vme-2-8")
epicsEnvSet("XXX","/home/bsrf-non/Documents/synApps_5_6/support/xxx-5-6")
epicsEnvSet("EPICS_BASE","/opt/base-3.14.12.1/")
# save_restore.cmd needs the full path to the startup directory, which
# envPaths currently does not provide
epicsEnvSet(STARTUP,/home/bsrf-non/Documents/synApps_5_6/support/xxx-5-6/iocBoot/iocLinux)
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Specify largest array CA will transport
# Note for N sscanRecord data points, need (N+1)*8 bytes, else MEDM
# plot doesn't display
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 64008
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in the software we just loaded (xxx.munch)
dbLoadDatabase("../../dbd/iocxxxLinux.dbd")
iocxxxLinux_registerRecordDeviceDriver(pdbbase)
drvAsynSerialPortConfigure("L0","/dev/ttyS2",0,0,0)
asynSetOption("L0",-1,"baud","115200")
asynSetOption("L0",-1,"bits","8")
asynSetOption("L0",-1,"parity","none")
asynSetOption("L0",-1,"stop","1")
asynSetOption("L0",-1,"clocal","Y")
asynSetOption("L0",-1,"crtscts","N")
asynOctetSetInputEos("L0",-1,"\r\n")
asynOctetSetOutputEos("L0",-1,"\r\n")
asynSetTraceIOMask("L0",-1,0x2)
#asynSetTraceMask("L0",-1,0x9)
asynSetTraceMask("L0",0,255)
################ 974 #####################
drvAsynSerialPortConfigure("serial_974","/dev/ttyS0",3,0,0)
asynSetOption("serial_974",0,"baud","9600")
asynSetOption("serial_974",0,"bits","8")
asynSetOption("serial_974",0,"parity","none")
asynSetOption("serial_974",0,"stop","2")
#asynSetOption("serial_974",0,"clocal","Y")
#asynSetOption("serial_974",0,"crtscts","N")
asynOctetSetInputEos("serial_974",0,"\r\n")
asynOctetSetOutputEos("serial_974",0,"\r\n")
asynSetTraceIOMask("serial_974",0,0x2)
asynSetTraceMask("serial_974",0,255)
asynOctetConnect("serial_974","serial_974")
asynOctetWriteRead("serial_974","INIT")
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort locking port
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort created lockPortPvt=0x91f2600
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort created lockPortPvt=0x91f2600, event=0x91f2610, mutex=0x91f2680
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort taking mutex 0x91f2680
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort queueing request
2015/04/28 10:37:30.793 serial_974 addr -1 queueRequest priority 0 not lockHolder
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort waiting for event
2015/04/28 10:37:30.793 asynManager::portThread port=serial_974 callback
2015/04/28 10:37:30.793 serial_974 asynManager::lockPortCallback signaling begin event
2015/04/28 10:37:30.793 serial_974 asynManager::lockPortCallback waiting for mutex from unlockPort
2015/04/28 10:37:30.793 serial_974 asynManager::lockPort got event from callback
2015/04/28 10:37:30.793 serial_974 flush
2015/04/28 10:37:30.793 /dev/ttyS0 flush
2015/04/28 10:37:30.793 /dev/ttyS0 write.
2015/04/28 10:37:30.793 /dev/ttyS0 write 6
INIT\r\n
2015/04/28 10:37:30.793 wrote 6 to /dev/ttyS0, return asynSuccess
2015/04/28 10:37:30.793 serial_974 wrote
INIT\r\n
2015/04/28 10:37:30.793 asynOctetSyncIO wrote:
INIT
2015/04/28 10:37:30.793 /dev/ttyS0 read.
2015/04/28 10:37:31.117 /dev/ttyS0 read 8
%0000000
2015/04/28 10:37:31.117 /dev/ttyS0 read 8, return 0
2015/04/28 10:37:31.117 serial_974 read
%0000000
2015/04/28 10:37:31.117 /dev/ttyS0 read.
2015/04/28 10:37:31.125 /dev/ttyS0 read 3
69\r
2015/04/28 10:37:31.125 /dev/ttyS0 read 3, return 0
2015/04/28 10:37:31.125 serial_974 read
69\r
2015/04/28 10:37:31.125 /dev/ttyS0 read.
2015/04/28 10:37:32.120 /dev/ttyS0 timeout handler.
2015/04/28 10:37:32.225 /dev/ttyS0 read 0, return 1
2015/04/28 10:37:32.225 serial_974 unlockPort
2015/04/28 10:37:32.225 serial_974 asynManager::unlockPort waiting for event
2015/04/28 10:37:32.225 serial_974 unlockPort unlock mutex 0x91f2680 complete.
2015/04/28 10:37:32.225 Error in WriteRead, nout 4 ninp=11 error
###################### setup 974 #############################
initScaler974("serial974","serial_974",0,100)
#< areaDetector.cmd
# Autosave info node example
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/autosave-4-8/asApp/Db/infoExample.db","P=xxx:")
# Soft function generator
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/FuncGen.db","P=xxx:,Q=fgen,OUT=xxx:m7.VAL")
# user-assignable ramp/tweak
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/ramp_tweak.db","P=xxx:,Q=rt1")
### save_restore setup
# We presume a suitable initHook routine was compiled into xxx.munch.
# See also create_monitor_set(), after iocInit() .
#< save_restore.cmd
# serial support
#< serial.cmd
# Motors
#dbLoadTemplate("basic_motor.substitutions")
#dbLoadTemplate("motor.substitutions")
#dbLoadTemplate("softMotor.substitutions")
#dbLoadTemplate("pseudoMotor.substitutions")
dbLoadRecords("/home/bsrf-non/Documents/KohzuAries/KohzuAriesSup/devKohzuAries.db","P=xxx:,R=,PORT=L0,A=0")
#< motorSim.cmd
< areaDetector.cmd
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 2000100
# Create a simDetector driver
simDetectorConfig("SIM1", 640, 480, 1, 50, 50000000)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/ADBase.template", "P=xxx:,R=SIM1:cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/simDetector.template","P=xxx:,R=SIM1:cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
# Create a second simDetector driver
simDetectorConfig("SIM2", 300, 200, 1, 50, 50000000)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/ADBase.template", "P=xxx:,R=SIM1:cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/simDetector.template","P=xxx:,R=SIM1:cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first simDetector driver.
NDStdArraysConfigure("SIM1Image", 3, 0, "SIM1", 0, 2000000)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=xxx:,R=image1:,PORT=SIM1Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStdArrays.template", "P=xxx:,R=image1:,PORT=SIM1Image,ADDR=0,TIMEOUT=1,TYPE=Int8,FTVL=UCHAR,NELEMENTS=1392640")
# Create a standard arrays plugin, set it to get data from second simDetector driver.
NDStdArraysConfigure("SIM2Image", 1, 0, "SIM2", 0, 2000000)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=xxx:,R=image2:,PORT=SIM2Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStdArrays.template", "P=xxx:,R=image2:,PORT=SIM2Image,ADDR=0,TIMEOUT=1,TYPE=Int8,FTVL=UCHAR,NELEMENTS=1392640")
# Load the database to use with Stephen Mudie's IDL code
#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/EPICS_AD_Viewer.template", "P=xxx:, R=image1:")
# Create a file saving plugin
NDFileNetCDFConfigure("SIM1File", 20, 0, "SIM1", 0)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=xxx:,R=netCDF1:,PORT=SIM1File,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=xxx:,R=netCDF1:,PORT=SIM1File,ADDR=0,TIMEOUT=1")
# Create an ROI plugin
NDROIConfigure("SIM1ROI", 20, 0, "SIM1", 0, 8, 20, 20000000)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=xxx:,R=ROI1:, PORT=SIM1ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template", "P=xxx:,R=ROI1:, PORT=SIM1ROI,ADDR=0,TIMEOUT=1")
### Allstop, alldone
#dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=xxx:")
### Scan-support software
# crate-resident scan. This executes 1D, 2D, 3D, and 4D scans, and caches
# 1D data, but it doesn't store anything to disk. (See 'saveData' below for that.)
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/sscan-2-7/sscanApp/Db/scan.db","P=xxx:,MAXPTS1=8000,MAXPTS2=1000,MAXPTS3=100,MAXPTS4=100,MAXPTSH=8000")
# A set of scan parameters for each positioner. This is a convenience
# for the user. It can contain an entry for each scannable thing in the
# crate.
dbLoadTemplate("scanParms.substitutions")
### Stuff for user programming ###
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userCalcs10.db","P=xxx:")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userCalcOuts10.db","P=xxx:")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userStringCalcs10.db","P=xxx:")
var aCalcArraySize, 2000
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userArrayCalcs10.db","P=xxx:,N=2000")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userTransforms10.db","P=xxx:")
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/userAve10.db","P=xxx:")
# string sequence (sseq) records
#dbLoadRecords("$(STD)/stdApp/Db/userStringSeqs10.db","P=xxx:")
############ add myself ##################
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db","P=xxx:,S=scan1,OUT=@asyn(serial974 0 2),DTYP=Asyn Scaler,FREQ=10,TP=1,TP1=0.5,PR1=1,CONT=1")
Error at or before ")" in file "/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db" line 123
Error: dbRecordHead: tempList not empty
at or before ")" in file "/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db" line 131
Error: syntax error
at or before "c�" in file "/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/scaler.db" line 131
# 4-step measurement
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/4step.db", "P=xxx:")
at or before ")" in file "/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/4step.db" line 1
Error: syntax error
at or before "@, �c�" in file "/home/bsrf-non/Documents/synApps_5_6/support/std-3-1/stdApp/Db/4step.db" line 1
# interpolation
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/interp.db", "P=xxx:,N=2000")
at or before ")" in file "/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/interp.db" line 7
Error: syntax error
at or before "A, �c�" in file "/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/interp.db" line 7
dbLoadRecords("/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/interpNew.db", "P=xxx:,Q=1,N=2000")
at or before ")" in file "/home/bsrf-non/Documents/synApps_5_6/support/calc-2-9/calcApp/Db/interpNew.db" line 7
Segmentation fault
my scan.db (add P1TV , T1PV did not know )
#! Generated by VisualDCT v2.5
#! DBDSTART
#! DBDEND
record(bi, "$(P)scanActive") {
field(DTYP, "Soft Channel")
field(INP, "0")
field(ZNAM, "Done")
field(ONAM, "Scanning")
record(bo, "$(P)AbortScan1") {
field(DISV, "0")
field(SDIS, "$(P)scan1.FAZE NPP NMS")
field(OUT, "$(P)scan1.EXSC CA NMS")
record(bo, "$(P)AbortScan2") {
field(DISV, "0")
field(SDIS, "$(P)scan2.FAZE NPP NMS")
field(OUT, "$(P)scan2.EXSC CA NMS")
record(bo, "$(P)AbortScan3") {
field(DISV, "0")
field(SDIS, "$(P)scan3.FAZE NPP NMS")
field(OUT, "$(P)scan3.EXSC CA NMS")
record(bo, "$(P)AbortScan4") {
field(DISV, "0")
field(SDIS, "$(P)scan4.FAZE NPP NMS")
field(OUT, "$(P)scan4.EXSC CA NMS")
record(bo, "$(P)AbortScanH") {
field(DISV, "0")
field(SDIS, "$(P)scanH.FAZE NPP NMS")
field(OUT, "$(P)scanH.EXSC CA NMS")
record(bo, "$(P)saveData_realTime1D") {
field(ZNAM, "No")
field(ONAM, "Yes")
record(bo, "$(P)scanPause") {
field(FLNK, "$(P)scanResumeSEQ.VAL PP MS")
field(OUT, "$(P)scanPauseSEQ.VAL PP MS")
field(ZNAM, "GO")
field(ONAM, "PAUSE")
record(calcout, "$(P)ScanDim") {
field(CALC, "a?a+(b|c|d|e):f")
field(INPA, "$(P)ScanDim1.VAL CP MS")
field(INPB, "$(P)ScanDimH1.VAL CP MS")
field(INPC, "$(P)ScanDimH2.VAL CP MS")
field(INPD, "$(P)ScanDimH3.VAL CP MS")
field(INPE, "$(P)ScanDimH4.VAL CP MS")
field(INPF, "$(P)scanH.BUSY CP MS")
field(INPG, "0")
field(INPH, "0")
field(OUT, "$(P)calcScanActive.A PP MS")
record(calcout, "$(P)ScanDim1") {
field(CALC, "d?4:c?3:b?2:a?1:0")
field(INPA, "$(P)scan1.BUSY CP MS")
field(INPB, "$(P)scan2.BUSY CP MS")
field(INPC, "$(P)scan3.BUSY CP MS")
field(INPD, "$(P)scan4.BUSY CP MS")
field(INPE, "0")
field(INPF, "0")
field(INPG, "0")
field(INPH, "0")
field(OUT, "0")
record(calcout, "$(P)calcScanActive") {
field(CALC, "a>0?1:0")
field(OUT, "$(P)scanActive.VAL PP MS")
record(fanout, "$(P)AbortScans") {
field(LNK1, "$(P)AbortScanH.VAL PP MS")
field(LNK2, "$(P)AbortScan1.VAL PP MS")
field(LNK3, "$(P)AbortScan2.VAL PP MS")
field(LNK4, "$(P)AbortScan3.VAL PP MS")
field(LNK5, "$(P)AbortScan4.VAL PP MS")
record(longout, "$(P)saveData_scanNumber") {
field(HOPR, "9999")
record(mbbi, "$(P)saveData_status") {
field(ZRST, "Inactive")
field(ONST, "Active")
field(TWST, "Mount err")
field(THST, "I/O err")
record(seq, "$(P)scanPauseSEQ") {
field(DISV, "0")
field(SDIS, "$(P)scanPause.VAL NPP MS")
field(DOL1, "1")
field(LNK1, "$(P)scanH.PAUS NPP MS")
field(DOL2, "1")
field(LNK2, "$(P)scan1.PAUS NPP MS")
field(DOL3, "1")
field(LNK3, "$(P)scan2.PAUS NPP MS")
field(DOL4, "1")
field(LNK4, "$(P)scan3.PAUS NPP MS")
field(DOL5, "1")
field(LNK5, "$(P)scan4.PAUS NPP MS")
record(seq, "$(P)scanResumeSEQ") {
field(PREC, "3")
field(DLY1, "1.")
record(stringout, "$(P)saveData_comment1") {
record(stringout, "$(P)saveData_comment2") {
record(stringout, "$(P)saveData_fileName") {
record(stringout, "$(P)saveData_fileSystem") {
record(stringout, "$(P)saveData_message") {
record(stringout, "$(P)saveData_subDir") {
record(stringout, "$(P)saveData_baseName") {
record(waveform, "$(P)saveData_config") {
field(NELM, "1000")
field(FTVL, "CHAR")
record(waveform, "$(P)saveData_fullPathName") {
field(NELM, "100")
field(FTVL, "CHAR")
record(sscan, "$(P)scan1") {
field(DESC, "Scan 1")
field(PINI, "YES")
field(PRIO, "HIGH")
field(MPTS, "$(MAXPTS1)")
field(NPTS, "10")
field(FPTS, "NO")
field(FFO, "OVERRIDE")
field(P1PV,"RPS1.VAL")
field(P1HR, "1")
field(P1PR, "5")
field(P2HR, "1")
field(P2PR, "5")
field(P3HR, "1")
field(P3PR, "5")
field(P4HR, "1")
field(P4PR, "5")
record(sscan, "$(P)scan2") {
field(DESC, "Scan 2")
field(PINI, "YES")
field(PRIO, "HIGH")
field(MPTS, "$(MAXPTS2)")
field(NPTS, "10")
field(FPTS, "NO")
field(T1PV, "$(P)scan1.EXSC")
field(P1HR, "1")
field(P1PR, "5")
field(P2HR, "1")
field(P2PR, "5")
field(P3HR, "1")
field(P3PR, "5")
field(P4HR, "1")
field(P4PR, "5")
record(sscan, "$(P)scan3") {
field(DESC, "Scan 3")
field(PINI, "YES")
field(PRIO, "HIGH")
field(MPTS, "$(MAXPTS3)")
field(NPTS, "10")
field(FPTS, "NO")
field(T1PV, "$(P)scan2.EXSC")
field(P1HR, "1")
field(P1PR, "5")
field(P2HR, "1")
field(P2PR, "5")
field(P3HR, "1")
field(P3PR, "5")
field(P4HR, "1")
field(P4PR, "5")
record(sscan, "$(P)scan4") {
field(DESC, "Scan 4")
field(PINI, "YES")
field(PRIO, "HIGH")
field(MPTS, "$(MAXPTS4)")
field(NPTS, "10")
field(FPTS, "NO")
field(T1PV, "$(P)scan3.EXSC")
field(P1HR, "1")
field(P1PR, "5")
field(P2HR, "1")
field(P2PR, "5")
field(P3HR, "1")
field(P3PR, "5")
field(P4HR, "1")
field(P4PR, "5")
record(sscan, "$(P)scanH") {
field(DESC, "Scan H")
field(PINI, "YES")
field(PRIO, "HIGH")
field(MPTS, "$(MAXPTSH)")
field(NPTS, "10")
field(FPTS, "NO")
field(P1HR, "0")
field(P1PR, "5")
field(P2HR, "0")
field(P2PR, "5")
field(P3HR, "0")
field(P3PR, "5")
field(P4HR, "1")
field(P4PR, "5")
field(ACQT, "1D ARRAY")
record(scalcout, "$(P)ScanDimH1") {
field(PINI, "YES")
field(CALC, "(aa['.',-1]=='EXSC') && a")
field(INPA, "$(P)scan1.T1CD CP MS")
field(INAA, "$(P)scan1.T1PV CP MS")
field(OUT, "0")
record(scalcout, "$(P)ScanDimH2") {
field(PINI, "YES")
field(INPA, "$(P)scan1.T2CD CP MS")
field(INAA, "$(P)scan1.T2PV CP MS")
field(OUT, "0")
record(scalcout, "$(P)ScanDimH3") {
field(PINI, "YES")
field(INPA, "$(P)scan1.T3CD CP MS")
field(INAA, "$(P)scan1.T3PV CP MS")
field(OUT, "0")
record(scalcout, "$(P)ScanDimH4") {
field(PINI, "YES")
field(INPA, "$(P)scan1.T4CD CP MS")
field(INAA, "$(P)scan1.T4PV CP MS")
field(OUT, "0")
record(longout, "$(P)saveData_maxAllowedRetries") {
field(HOPR, "9999")
field(DOL, "10")
field(DRVH, "1000000")
record(longout, "$(P)saveData_currRetries") {
field(HOPR, "9999")
record(longout, "$(P)saveData_retryWaitInSecs") {
field(HOPR, "9999")
field(DOL, "15")
record(longout, "$(P)saveData_abandonedWrites") {
field(HOPR, "9999")
record(longout, "$(P)saveData_totalRetries") {
field(HOPR, "9999")
At 2015-04-21 01:36:58, "Goetze, Kurt A." < [email protected]> wrote:
Hi Xing Li,
You will know what your macro values should be based on the line that loads the scaler database into your ioc, usually in a startup command file called “st.cmd”.
In our case st.cmd loads “vme.cmd”, which contains a line like this:
dbLoadRecords(“$(STD)/stdApp/Db/scaler.db”,”P=xyz:,S=scaler1,OUT=#C0 S0 @,DTYP=Joerger VSC8/16,FREQ=10000000”)
“P=xyz:” and “S=scaler1” are the macro values you care about in this case because they are used in the PV name, and that’s what you’re connecting to with medm.
Hope this helps,
Kurt
[email protected] [mailto:[email protected]]
On Behalf Of l123173
Sent: Monday, April 20, 2015 10:18 AM
To: [email protected]
Subject: macro value
Hi tech-talk,
computer : linux redhat6.0 3.14.12.1 synApp5.6
I startup the medm with "medm -x -macro "P=xxx:,S=scaler974" /home/bsrf-non/Documents/synApps_5_6/support/all_adl/scaler.adl", but it could connect.
I think it is the macro value, because I copy it from others( I could not contact him )and it worked well before. Recently, I delete the synApp by careless, it did not work evenif I rebuilt the synApp.
I know nothing about how to set the macro value , could you teach me how to know your macro value.
Thanks for you advice!
Thank you,
Xing Li
