1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Problem building seq-2-2-1 on Windows
To: "'Benjamin Franksen'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Wed, 29 Apr 2015 16:23:49 +0000
Hi Ben,
I have now tested building seq-2.2.2 on Windows.  It builds OK on the win32-x86-static and windows-x64-static architectures.  However, it fails on the dynamic builds, win32-x86 and windows-x64.  It also fails in cygwin-x86, which is the gcc compiler.
Here is the output from the windows-x64 build:
make[3]: Entering directory `J:/epics/devel/seq/src/snc/O.windows-x64'
link -nologo  /LTCG /incremental:no /opt:ref /release   /MACHINE:X64              -out:snc.exe        lexer.obj snl.obj main.obj node.obj var_types.obj analysis.obj gen_code.obj ge
n_ss_code.obj gen_tables.obj sym_table.obj builtin.obj type_check.obj     ..\\..\\..\\lib\\windows-x64\\seq.lib  ..\\..\\..\\lib\\windows-x64\\pv.lib  H:\\epics\\base-3.14.12.5\\li
b\\windows-x64\\ca.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\Com.lib
var_types.obj : error LNK2001: unresolved external symbol __imp_prim_type_name
gen_tables.obj : error LNK2001: unresolved external symbol __imp_prim_type_tag_name
snc.exe : fatal error LNK1120: 2 unresolved externals
make[3]: *** [snc.exe] Error 1120
make[3]: Leaving directory `J:/epics/devel/seq/src/snc/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `J:/epics/devel/seq/src/snc'
make[1]: *** [snc.install] Error 2
make[1]: Leaving directory `J:/epics/devel/seq/src'
make: *** [src.install] Error 2
Here is the output from the cygwin-x86 build:
var_types.o:var_types.c:(.text+0x124): undefined reference to `_imp__prim_type_name'
var_types.o:var_types.c:(.text+0x2a7): undefined reference to `_imp__prim_type_name'
var_types.o:var_types.c:(.text+0x1285): undefined reference to `_imp__prim_type_name'
gen_tables.o:gen_tables.c:(.text+0x447): undefined reference to `_imp__prim_type_tag_name'
collect2: error: ld returned 1 exit status
/corvette/usr/local/epics/base-3.14.12.5/configure/RULES_BUILD:186: recipe for target 'snc.exe' failed
make[4]: *** [snc.exe] Error 1
/corvette/usr/local/epics/base-3.14.12.5/configure/RULES_ARCHS:64: recipe for target 'install.cygwin-x86' failed
make[3]: *** [install.cygwin-x86] Error 2
/corvette/usr/local/epics/base-3.14.12.5/configure/RULES_DIRS:87: recipe for target 'snc.install' failed
make[2]: *** [snc.install] Error 2
/corvette/usr/local/epics/base-3.14.12.5/configure/RULES_DIRS:87: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
/corvette/usr/local/epics/base-3.14.12.5/configure/RULES_DIRS:87: recipe for target '/cygdrive/j/epics/devel/seq-2-2-2.install' failed
make: *** [/cygdrive/j/epics/devel/seq-2-2-2.install] Error 2
I will try to fix the problem.
Sent: Wednesday, April 29, 2015 10:45 AM
To: 'Benjamin Franksen'
Cc: '[email protected]'
Apologies, I see that there is a known problem on seq-2-2-1 for Windows.  I will try seq-2-2-2.
Sent: Wednesday, April 29, 2015 10:40 AM
To: Benjamin Franksen
Subject: Problem building seq-2-2-1 on Windows
Hi Ben,
I am getting errors building seq-2-2-1 on all Windows architectures supported in EPICS base-3.14.12.5: win32-x86, win32-x86-static, windows-x64, windows-x64-static.
Here is the error for win32-x86-static:
make[2]: Entering directory `J:/epics/devel/seq/src/snc'
make -C O.win32-x86-static -f ../Makefile TOP=../../.. \
            T_A=win32-x86-static install
make[3]: Entering directory `J:/epics/devel/seq/src/snc/O.win32-x86-static'
link -nologo  /LTCG /incremental:no /opt:ref /release                -out:snc.exe        lexer.obj snl.obj main.obj node
.obj var_types.obj analysis.obj gen_code.obj gen_ss_code.obj gen_tables.obj sym_table.obj builtin.obj type_check.obj
H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\recIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\softDev
Ioc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\miscIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static
\\rsrvIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\dbtoolsIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x
86-static\\asIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\dbIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32
-x86-static\\registryIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\dbStaticIoc.lib  H:\\epics\\base-3.14.12
.5\\lib\\win32-x86-static\\ca.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86-static\\Com.lib  H:\\epics\\base-3.14.12.5\
\lib\\win32-x86-static\\Com.lib  ..\\..\\..\\lib\\win32-x86-static\\seq.lib   ws2_32.lib advapi32.lib user32.lib kernel3
2.lib winmm.lib
seq.lib(seq_main.obj) : error LNK2001: unresolved external symbol _pv_value_sizes
seq.lib(seq_main.obj) : error LNK2001: unresolved external symbol _pv_sizes
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol _pvSysFlush
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol _pvTimeGetCurrentDouble
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol _pvSysAttach
seq.lib(seq_cmd.obj) : error LNK2001: unresolved external symbol _pvSysCreate
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pvVarGetCount
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pv_severity_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pvVarMonitorOff
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pv_status_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pvVarDestroy
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pv_value_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pvVarCreate
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pvVarMonitorOn
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol _pv_stamp_offsets
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol _pvVarPutNoBlock
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol _pvVarGetCallback
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol _pvVarPutCallback
snc.exe : fatal error LNK1120: 18 unresolved externals
make[3]: Leaving directory `J:/epics/devel/seq/src/snc/O.win32-x86-static'
make[2]: *** [install.win32-x86-static] Error 2
Here is the error for windows-x64-static:
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
            T_A=windows-x64-static install
make[3]: Entering directory `J:/epics/devel/seq/src/snc/O.windows-x64-static'
n_ss_code.obj gen_tables.obj sym_table.obj builtin.obj type_check.obj     H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\recIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x6
4-static\\softDevIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\miscIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\rsrvIoc.lib  H:\\epics\\base-3.14.12.
5\\lib\\windows-x64-static\\dbtoolsIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\asIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\dbIoc.lib  H:\\epics\
\base-3.14.12.5\\lib\\windows-x64-static\\registryIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\dbStaticIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\
ca.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\Com.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64-static\\Com.lib  ..\\..\\..\\lib\\windows-x64-static\\seq.lib   ws2
_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
seq.lib(seq_main.obj) : error LNK2001: unresolved external symbol pv_value_sizes
seq.lib(seq_main.obj) : error LNK2001: unresolved external symbol pv_sizes
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol pvSysFlush
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol pvTimeGetCurrentDouble
seq.lib(seq_task.obj) : error LNK2001: unresolved external symbol pvSysAttach
seq.lib(seq_cmd.obj) : error LNK2001: unresolved external symbol pvSysCreate
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pvVarGetCount
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pv_severity_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pvVarMonitorOff
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pv_status_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pvVarDestroy
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pv_value_offsets
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pvVarCreate
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pvVarMonitorOn
seq.lib(seq_ca.obj) : error LNK2001: unresolved external symbol pv_stamp_offsets
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol pvVarPutNoBlock
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol pvVarGetCallback
seq.lib(seq_if.obj) : error LNK2001: unresolved external symbol pvVarPutCallback
make[3]: Leaving directory `J:/epics/devel/seq/src/snc/O.windows-x64-static'
make[2]: *** [install.windows-x64-static] Error 2
Here is the error for win32-x86 (dynamic build):
make[1]: Entering directory `J:/epics/devel/seq/src/snc/O.win32-x86'
H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\recIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\softDevIoc.lib  H:\\e
pics\\base-3.14.12.5\\lib\\win32-x86\\miscIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\rsrvIoc.lib  H:\\epics\\ba
se-3.14.12.5\\lib\\win32-x86\\dbtoolsIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\asIoc.lib  H:\\epics\\base-3.14
.12.5\\lib\\win32-x86\\dbIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\registryIoc.lib  H:\\epics\\base-3.14.12.5\
\lib\\win32-x86\\dbStaticIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\ca.lib  H:\\epics\\base-3.14.12.5\\lib\\win
32-x86\\Com.lib  H:\\epics\\base-3.14.12.5\\lib\\win32-x86\\Com.lib  ..\\..\\..\\lib\\win32-x86\\seq.lib
var_types.obj : error LNK2001: unresolved external symbol _prim_type_name
gen_tables.obj : error LNK2001: unresolved external symbol _prim_type_tag_name
make[1]: *** [snc.exe] Error 1120
make[1]: Leaving directory `J:/epics/devel/seq/src/snc/O.win32-x86'
make: *** [install.win32-x86] Error 2
Here is the error for windows-x64 (dynamic build):
n_ss_code.obj gen_tables.obj sym_table.obj builtin.obj type_check.obj     H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\recIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\soft
DevIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\miscIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\rsrvIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\dbtools
Ioc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\asIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\dbIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\registryIoc.li
b  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\dbStaticIoc.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\ca.lib  H:\\epics\\base-3.14.12.5\\lib\\windows-x64\\Com.lib  H:\\epic
s\\base-3.14.12.5\\lib\\windows-x64\\Com.lib  ..\\..\\..\\lib\\windows-x64\\seq.lib
var_types.obj : error LNK2001: unresolved external symbol prim_type_name
gen_tables.obj : error LNK2001: unresolved external symbol prim_type_tag_name
RE: Problem building seq-2-2-1 on Windows Mark Rivers
Prev: RE: Problem building seq-2-2-1 on Windows Mark Rivers
Next: Base R3.15.2-rc1 release Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Problem building seq-2-2-1 on Windows Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
