1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: USB-to-serial
Date: Tue, 19 May 2015 19:33:00 +0000
​I have a Eurotherm 2416 temperature controller which travels with me. I was using a desktop computer to run an EPICS IOC, but I realized this was foolish and am replacing it with a laptop. The desktop has a built-in serial port, while the laptop uses a USB-to-serial port. I'm running the same EPICS configuration with some updated modules, but the serial communications which worked on the desktop do not work on the laptop. I get errors with "No reply from device".
I'm hoping someone can explain the confusing results of my search of tech-talk. Some posts suggest that I just plug in the USB-to-serial and use the /dev/ttyUSB0 device which is automatically created. Others suggest that I need to use a command like "modprobe ftdi_sio vendor=0x67b product=0x2303", which gives the error "ftdi_sio: unknown parameter 'vendor' ".
Question: do I need to use the "modprobe ftdi_sio" command, and if so why is the 'vendor' parameter giving it trouble?
Details:
Eurotherm 2416 temperature controller with serial interface
base-3.15.1
asyn-4-26
stream-2-6a
sateco Eurotherm protocols from X.L. Wang
RE: USB-to-serial Mark Rivers
Re: USB-to-serial Johnson, Andrew N.
Re: USB-to-serial Dirk Zimoch
Prev: RE: ChannelArchiver and EPICS4 Malitsky, Nikolay D
Next: RE: USB-to-serial Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Setting waveform values from python script Davide Marcato
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
