1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS web GUIs using websockets
To: <[email protected]>, <[email protected]>
Date: Wed, 20 May 2015 09:36:29 +0000
Hi Emmanuel,
One requirement is that the client should only need an up to date browser, so a python or C++ client is not an option.
I found a couple of options for running QML in the browser, both of which seem to be prototypes:
http://silk.qtquick.me/
https://github.com/Plaristote/qmlweb
Have you used either of them?
Tom Cobb
+44 (0)1235 778582
From: [email protected] [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: 19 May 2015 23:25
To: Cobb, Tom (DLSLtd,RAL,TEC); EPICS mailing list
Tom,
http://doc.qt.io/qt-5/qtwebsockets-examples.html
http://doc.qt.io/qt-5/qtwebsockets-echoserver-example.html
As you will find out, websocket interfaces are not limited to client's web browser only (i.e HTML only).
All the Qt based cloud services are using websockets. As a result, great care has been taken to easily implement websockets with Qt.
http://www.slideshare.net/emayssat/qtdd14-give-a-push-to-your-qt-application-with-websockets
If you want a python client, have a look at pyqt5 and
http://stackoverflow.com/questions/15092076/pyqt-and-websocket-client-listen-websocket-in-background
If you understand how Qt works (start a dummy QML project in Qt Creator, and you understand signals and slots), you will realize that QML is the easiest way to write your client (with qt)
http://www.qmlbook.com
http://doc.qt.io/qt-5/qt-websockets-qmlmodule.html
I hope this helps,
Emmanuel Mayssat
http://www.epicsqt.org
> To: [email protected]
> Subject: EPICS web GUIs using websockets
> Date: Tue, 19 May 2015 10:03:42 +0000
> Hi all,
> I'm looking to create a web interface for a device running embedded Linux including an on-board IOC. I would like to run a small python based webserver on the device which communicated to the IOC and exposed a web-socket connection to allow the GUI running in the client's browser to set and get PVs.
> A while back there was a thread on browser based EPICS GUIs:
> http://www.aps.anl.gov/epics/tech-talk/2014/msg01824.php
> There were a few responses that used CA on the server and web-sockets to communicate the data to the client:
> * http://webpda.org/ (last commit 2013)
> * http://epaper.kek.jp/ICALEPCS2013/papers/tuppc110.pdf (can't find the code)
> * https://github.com/AustralianSynchrotron/web-epics (last commit March 2014)
> * https://github.com/diirt/diirt/tree/master/pods/web-pods (last commit April 2015)
> I found that webpods was the most developed, and the only one with a decent specification:
> * https://github.com/diirt/diirt/wiki/WebPods-Protocol-Specification-v1
> But it was written in java, so I started writing a small Python server so I could reuse the _javascript_ library:
> * https://github.com/dls-controls/PyPODS
> I've now reached the proof of principle stage, and as far as I can tell, no-one has got beyond that point on any of these projects! Has anyone actually deployed a project like this? Is anyone actively working on something like this?
> Thanks,
> Tom Cobb
> This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
Re: EPICS web GUIs using websockets Jon Brinkmann
EPICS web GUIs using websockets tom.cobb
RE: EPICS web GUIs using websockets Emmanuel Mayssat
Prev: Re: Problem building seq-2-2-1 on Windows Benjamin Franksen
Next: RE: EPICS device driver support for Tektronix AFG3000C Ibrahim Saleh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS web GUIs using websockets Emmanuel Mayssat
Next: Re: EPICS web GUIs using websockets Jon Brinkmann
