1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about device support
To: Florian Feldbauer <[email protected]>
Date: Tue, 26 May 2015 14:46:01 +0200
Hi Florian,
Yet another thing to keep in mind is the level at which you want locking of things to happen. Usually (in the blocking case), a port driver locks its port, does the IO, then unlocks its port.
Some years ago at BESSY we were thinking how our CAN-Bus driver would fit the ASYN model. CANopen compliant, i.e. many nodes per bus (~30), many variables per node (~15), and some types of indexed variables with many values per variable (~120). The only thing that we wanted to be locked (between request and reply) was the variable, to avoid sending commands on two different indexes of the same variable without waiting for an answer. Something like that does not fit the ASYN model well. For each fully populated bus segment you would basically end up with ~450 instances of a blocking "variable" port driver, all talking to the same non-blocking lower level "bus" port driver. Starting 450 threads per bus made this look very unattractive. In the end we kept our patchwork non-ASYN driver, as (for this and other reasons) the rewriting effort was not justified well enough.
~Ralph
Re: Question about device support Florian Feldbauer
RE: Question about device support Mark Rivers
Prev: RE: Question about device support Mark Rivers
Next: Re: Question about device support Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
