1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Rotating or deleting procServ log files
To: [email protected]
Date: Tue, 02 Jun 2015 17:02:49 -0400
procServ >= 2.6 will re-open it's log file when SIGHUP is received (as
is typical of unix daemons).
https://github.com/epicsdeb/sysv-rc-softioc/blob/master/debian/sysv-rc-softioc.logrotate
On 06/02/2015 04:45 PM, Wesley Moore wrote:
> Mark,
> I had the same issue with some very verbose iocs. What I did to solve this was by using logrotate to manage the log files. Here's the basics of my config (note you can rotate on size too):
> # /etc/logrotate.d/softiocs
> <path to logs>/*log {
> notifempty
> copytruncate
> daily
> rotate 7
> dateext
> compress
> Log files end up like this:
> -rw-r--r-- 1 epics clas-3 311M Jun 2 16:41 iocsvtDaqDpm0.log
> -rw-r--r-- 1 epics clas-3 4.2M May 27 04:12 iocsvtDaqDpm0.log-20150527.gz
> -rw-r--r-- 1 epics clas-3 2.1M May 28 04:09 iocsvtDaqDpm0.log-20150528.gz
> -rw-r--r-- 1 epics clas-3 2.3M May 29 04:06 iocsvtDaqDpm0.log-20150529.gz
> -rw-r--r-- 1 epics clas-3 2.3M May 30 04:07 iocsvtDaqDpm0.log-20150530.gz
> -rw-r--r-- 1 epics clas-3 2.4M May 31 04:11 iocsvtDaqDpm0.log-20150531.gz
> -rw-r--r-- 1 epics clas-3 2.4M Jun 1 04:07 iocsvtDaqDpm0.log-20150601.gz
> -rw-r--r-- 1 epics clas-3 2.5M Jun 2 04:08 iocsvtDaqDpm0.log-20150602.gz
> Wesley
>> From: "Mark Rivers" <[email protected]>
>> To: "Ralph Lange" <[email protected]>
>> Cc: "EPICS Tech-Talk" <[email protected]>
>> Sent: Tuesday, June 2, 2015 4:22:07 PM
>> Subject: Rotating or deleting procServ log files
>> Ralph,
>> procServ log files sometimes get very large, so we would like to rotate them,
>> and or delete them and start a new one without restarting the procServ process.
>> Is this possible? I found that if I rename the log file procServ just kept
>> writing to the renamed file. If I delete the log file procServ does not create
>> a new one, it just silently continues without logging anything.
>> Is there a correct way to replace the current log file without restarting the
>> procServ process?
>> This is procServ 2.6.0.
>> Thanks,
>> Mark
Rotating or deleting procServ log files Mark Rivers
Re: Rotating or deleting procServ log files Wesley Moore
Prev: Re: Rotating or deleting procServ log files Wesley Moore
Next: Re: Rotating or deleting procServ log files Jani Hakala
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Rotating or deleting procServ log files Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
