1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base-3.14.12.5 installation error
To: Alex George <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 22 Jun 2015 12:08:18 -0500
Hi Alex,
On 06/22/2015 11:48 AM, Alex George wrote:
> I was looking over the error output and it looked like some of it wasn't
> copied over in the original message:
> /make[3]: *Entering directory
> `C:/epics/base-3.14.12.5/src/softIoc/O.windows-x64'*/
Ok, that was the line I was looking for which you had omitted -- no problem.
>     /C:\epics\base-3.14.12.5\src\softIoc>make/
>     /perl ../../bin/windows-x64/makeMakefile.pl O.windows-x64 ../../../
>     /perl -MExtUtils::Command -e mkpath O.Common/
>     /make -C O.windows-x64 -f ../Makefile TOP=../../.. \/
>     /            T_A=windows-x64 install/
>     /make[1]: Entering directory
>     `C:/epics/base-3.14.12.5/src/softIoc/O.windows-x64'/
>     /perl ../../../bin/windows-x64/makeIncludeDbd.pl base.dbd dlload.dbd
>     system.dbd softIocInclude.dbd/
>     /echo "../O.Common/softIocInclude.dbd : ../Makefile" >> softIoc.dbd.d/
>     /"Expanding dbd"/
>     /"Installing created dbd file ../../../dbd/softIoc.dbd"/
>     /perl ../../../bin/windows-x64/registerRecordDeviceDriver.pl
>     ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver
>     C:/epics/base/
>     /-3.14.12.5 > softIoc.tmp/
>     /Can't open perl script
>     "../../../bin/windows-x64/registerRecordDeviceDriver.pl": No such
>     file or directory/
>     /make[1]: *** [softIoc_registerRecordDeviceDriver.cpp] Error 2/
>     /make[1]: Leaving directory
>     /make: *** [install.windows-x64] Error 2/
Ok, it is doing the right thing then. Can you run this to display the
ACLs of that script:
  cd C:/epics/base-3.14.12.5/src/softIoc
  icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
>     C:\epics\base-3.14.12.5\src\softIoc>make --version
>     GNU Make 3.81
>     C:\epics\base-3.14.12.5\src\softIoc>perl -v
>     This is perl 5, version 20, subversion 2 (v5.20.2) built for
>     MSWin32-x64-multi-thread
Those look Ok.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: EPICS base-3.14.12.5 installation error Alex George
Re: EPICS base-3.14.12.5 installation error Johnson, Andrew N.
Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Prev: Re: EPICS base-3.14.12.5 installation error Alex George
Next: Re: EPICS base-3.14.12.5 installation error Alex George
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
