1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multi-channel analog i/p
To: <[email protected]>, <[email protected]>
Date: Tue, 23 Jun 2015 08:40:15 +0000
Hi Paul,
This is basically a software triggered analogue read. Often ai’s have hardware triggers to tell the ADC to sample – frequently across many channels as you propose. The triggers have to be supported by the driver layer, of course. A software trigger (as you propose) would typically be represented by a binary output record, which would cause the driver to trigger sampling, and the values would be fed back to the Ai records by having them I/O Intr scanned.
However, all this needs proper support in the driver. It is best to start off with a board with a driver that supports all this, but otherwise you need to write a suitable driver for your board. In the VME world, we use the Hytec 8401 for this sort of job – the software manual is on the Hytec website: http://www.hytec-electronics.co.uk/PDF/Hytec%20EPICS%20Device%20Driver%20User%20Manual.pdf.
There is also some areaDetector work going on to generate a 2-D dataset from multiple triggers across many channels – that may be interesting depending on your use case.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
From: [email protected] [mailto:[email protected]] On Behalf Of Stephen Paul
Sent: 23 June 2015 06:37
To: [email protected]
Subject: multi-channel analog i/p
Hi guys,
I have a 32-channel analog input board. I don't want to use 32 ai records reach reading directly from h/w.
Instead , I first want a record and its device support to read all the channels from the board in one go and then pass these values to individual 32 ai records for conversion.
Can anyone suggest what type of record I can use before ai record to achieve this ?
Stefen.
multi-channel analog i/p Stephen Paul
Prev: multi-channel analog i/p Stephen Paul
Next: multi-channel analog i/p bob dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: multi-channel analog i/p Hartman, Steven M.
