1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: multi-channel analog i/p
To: "'Stephen Paul'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Jun 2015 13:24:15 +0000
Hi Stefan,
The Acromag IP-330 driver (https://github.com/epics-modules/ip330) might be an example to look at.  It is a 16-bit 16-channel ADC.
It supports:
-          Hardware interrupts
-          ai records with SCAN=I/O Intr.  This works OK to several hundred samples/s on all 16 channels.
-          ai records with periodic processing and averaging. For example the driver is sampling at 2000 samples/s and the record is processing at 10 Hz then it will average 200 readings.
-          Time-series mca records
-          Fast-feedback with the epid record
I have tested 2000 samples/s processing 16 ai records, 16 time-series records, and 1 fast-feedback record on a rather slow VME processor.
From: [email protected] [mailto:[email protected]] On Behalf Of Stephen Paul
Sent: Tuesday, June 23, 2015 12:37 AM
To: [email protected]
Subject: multi-channel analog i/p
Hi guys,
I have a 32-channel analog input board. I don't want to use 32 ai records reach reading directly from h/w.
Instead , I first want a record and its device support to read all the channels from the board in one go and then pass these values to individual 32 ai records for conversion.
Can anyone suggest what type of record I can use before ai record to achieve this ?
Stefen.
multi-channel analog i/p Stephen Paul
Prev: Re: multi-channel analog i/p Hartman, Steven M.
Next: RE: EPICS base-3.14.12.5 installation error freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: multi-channel analog i/p Kasemir, Kay
Next: multi-channel analog i/p bob dalesio
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
