1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: UCHAR to BitArray conversion(binary-bits array)
To: ishita bhatia <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 29 Jun 2015 09:13:15 +0200
You are not really making you point clear, sorry.
Again: what is the C declaration you would use to declare the data in the type you want?
Just a wild guess: have you tried looking at the VAL field of your mbbiDirect record? It's not an array, and there is no "binary bit" type in C, but the VAL field contains all the bits in a single 32bit value, which might be what you are looking for.
Cheers,
~Ralph
On 29/06/2015 07:32, ishita bhatia wrote:
Hello Mark,
As u have asked in previous post, my end goal is to get reading of OPTO card in form of binary (1's and 0's) where 1 would represent ON status and 0 would represent OFF status. That is why the data which I am receiving from waveform record(data type: Uchar), I want that data in form of Binary. Now as I want data in form of binary, I passed the output of waveform record in mbbiDirect but the output I am getting from mbbiDirect is in form of 1 binary bit at a time....but I want output as array of binary bits(32 binary bits as output of my waveform record contains 4 bytes). So please tell me how to get such output or which record should I use to get that output.
I hope I am making my point clear.
Re: UCHAR to BitArray conversion(binary-bits array) ishita bhatia
Prev: Re: UCHAR to BitArray conversion(binary-bits array) ishita bhatia
Next: RE: UCHAR to BitArray conversion(binary-bits array) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
