1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: setting NTP time sync interval on vxWorks
To: tech-talk <[email protected]>
Date: Fri, 3 Jul 2015 16:36:10 +0800 (GMT+08:00)
Hi all,
I want to know how to set the NTP time sync interval on vxWorks. The output of "NTPTime_Report 1" shows the default interval is 60 seconds:
timingMain>NTPTime_Report 1
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2015-07-03 16:06:19.062927
OS tick rate = 60 Hz (nominal)
Measured tick rate = 60.007 Hz
NTP Server = 10.1.201.31
value = 0 = 0x0
I can modify the variable "NTPTimeSyncInterval" in file $(EPICS_BASE)\src\libCom\osi\osiNTPTime.c to change the sync interval. Is there a command can be used in ioc shell?
Best regards,
Zhang Yuliang
Re: setting NTP time sync interval on vxWorks Ralph Lange
Prev: Re: stream device - multiple values from a string Mark Rivers
Next: Re: setting NTP time sync interval on vxWorks Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: stream device - multiple values from a string peter.owens
