1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS TCP server
To: yann stephen <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 6 Jul 2015 22:22:38 +0000
Hi Stephen,
The "cas warning" messages are normal.
It should not create an ipSNCServer executable.  That is an SNL program which is part of your IOC application.  That is working OK since you did not get an error from this command:
seq("ipSNCServer", "P=testIPServer:, PORT=P5002")
These errors:
> sevr=minor ipSNCServer[0](after 5 sec): assigned=3, connected=0, monitored=0, got monitor=0
are happening because your records don't have the same prefix as the SNL program is expecting.  Your st.cmd file has these 2 lines:
epicsEnvSet "P" "$(P=testIPServer)"
dbLoadDatabase "dbd/myexample.dbd"
That does not look correct to me.  I think the first line should be:
epicsEnvSet "P" "testIPServer:"
You can use the iocsh "dbl" command to see the names of the records that are loaded.  This is what I get from the asyn/asynTestIPServerApp IOC:
epics> dbl
testIPServer:connected
testIPServer:stringInput
testIPServer:stringOutput
From: [email protected] [[email protected]] on behalf of yann stephen [[email protected]]
Sent: Monday, July 06, 2015 1:27 PM
To: [email protected]
Subject: EPICS TCP server
Good day!
i am experimenting with epics tcp socket capabilities using asyn driver. having done some reading , install the asyn package and the epics sequencer as well. under the asyn directory there is an testIPServer directory with a read me file that tell to setup the SNCSEQ in the realese variable to use the sequencer capabilities. this folder provide a ipSNCServer.st and ipEchoServer.c files that i am trying to incorporate to my application to have a server  listening  at a specific port.
now, i build my application and under top/xxxApp/src i modified the Makefile as the one attached to this email.
i also modified the release file under configure to include the different variable path.
i modified my st.cmd file as well to include the ip port configuration as attached as well.
my problem is this, when a run make under this directory, xxxApp/src it create two file, the application executable and the sncExample executable but never an ipSNCServer executable. when i run the st.cmd i get this output.
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 53146,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
## Start any sequence programs
#seq sncExample, "user=myHost"
#ipEchoServer("P5001")
Sequencer release 2.1.13, compiled Wed Apr  1 07:55:20 2015
Spawning sequencer program "ipSNCServer", thread 0x9f89330: "ipSNCServer"
epics> sevr=minor ipSNCServer[0](after 2 sec): assigned=3, connected=0, monitored=0, got monitor=0
sevr=minor ipSNCServer[0](after 10 sec): assigned=3, connected=0, monitored=0, got monitor=0
sevr=minor ipSNCServer[0](after 18 sec): assigned=3, connected=0, monitored=0, got monitor=0
sevr=minor ipSNCServer[0](after 31 sec): assigned=3, connected=0, monitored=0, got monitor=0
the readme file provide this output,
iocInit: All initialization complete
SEQ Version 2.0.10: Thu Jan  5 13:14:09 2006
Spawning state program "ipSNCServer", thread 0x809e720: "ipSNCServer"
epics>
i am running epics 3.14 on ubuntu 12.04
Thank for any assistance.
Yann
RE: EPICS TCP server Mark Rivers
EPICS TCP server yann stephen
Prev: EPICS TCP server yann stephen
Next: RE: EPICS TCP server Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
