1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: streamdevice redirective problem
To: tech-talk <[email protected]>
Date: Tue, 7 Jul 2015 14:25:53 +0800
hi,
I want to use streamdevice to send an array of bytes to power supply controller, for example, 1024 bytes data.
so I use one soft waveform record (PS:T1) to prepare the array data, if a client such as caput or a python script write data to PS:T1, it will trigger PS:T2 in streamdevice to output data to power supply.
In PS:T2's protocol file, the out value is coming from PS:T1.
But it can't work, would you please give me some advice?
record(waveform, "PS:T1")
field(SCAN, "Passive")
field(DTYP, "Soft Channel")
field(NELM, "1024")
field(FTVL, "UCHAR")
field(FLNK, "$(USER):T2")
record(waveform, "PS:T2")
field(DTYP, "stream")
field(NELM, "1024")
# field(FTVL, "UCHAR")
field(INP, "@ps.proto set_waveform $(terminal)")
protocol file is like following:
set_waveform {
out "%(\PS:T1)r"; # in "\?" $1 0x00 0x00 0x00 0x00;
Best wishes
Geyang 2015-07-07
Prev: Re: EPICS TCP server Andrew Johnson
Next: Re: setting NTP time sync interval on vxWorks Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Job Opening at the Australian Synchrotron Paul Martin
