1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: how NOT to update the record
To: Tasaddaq Khan <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Jul 2015 22:48:58 +0000
Hi Tasaddaq,
You can use the OOPT field to specify when the output link should be executed.  c.OOPT="When Non-zero"
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Tasaddaq Khan [[email protected]]
Sent: Wednesday, July 08, 2015 1:59 PM
To: [email protected]
Subject: how NOT to update the record
Dear all
I have three records, when the value in the record "b" is "1" the value in the record c is calculated and the record d is updated as well. Upto this the things are working fine. But I want one more thing that when the b=0, the value of record "c" should become the zero (that is happening) but it should not send the value zero to the record d means at b=0 record c should be updated but it should not update the record d. I want to keep the last value of record d so that when b=1 again then record d should start from the last value that it will hold. Please tell me how to do this?
record (bi,"b"){
field(FLNK, "c")
record (calcout, "c"){
field(SCAN, "1 second")
field(INPA, "c")
field(INPB,"b")
field(INPC,"1")
field(CALC,"B=1?A+C:0")
field(OUT,"d PP")
record(calcout, "d"){
field(INPA, "c")
field(INPB,"1")
field(CALC,"A+B")
regards,
Tasaddaq
how NOT to update the record Tasaddaq Khan
Prev: how NOT to update the record Tasaddaq Khan
Next: how to write array data to waveform record in cothread? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: how NOT to update the record Mooney, Tim M.
