1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stepper Motor Controllers
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Jul 2015 15:11:46 +0000
For stepper motors, I like the combination of OMS MAXv controllers and ACS StepPack drivers.
The controller is well supported in EPICS, the driver is electrically silent when the motor is not moving, and no encoder is required.  The vast majority of motors at APS are controlled in this way.
For servo motors, I like the Aerotech Ensemble.  It's also well supported in EPICS, and has the ability to
generate data-acquisition triggers at up to 8000 user-specified positions, or an unlimited number of regularly spaced positions.  Things I don't like: Aerotech motors must be configured via a Windows application, and their manual is in the form of Windows help files.  It's a good application, and the help files are very good, but I don't like the fact that Windows is required.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Mark Davis [[email protected]]
Sent: Friday, July 10, 2015 9:52 AM
To: [email protected]
Subject: Stepper Motor Controllers
Hi all,
I am currently in the process of reviewing the capabilities of DC
Stepper Motor Controller/Drivers and was wondering what other labs are
currently using and what they like/dislike about them.
I have read Matthew Pearson's summary from 8/2010 regarding the Delta
Tau VME Turbo PMAC 2, Delta Tau Geobrick LVM, Newport XPS.
 From his description, I assume the Delta Tau Geobrick LV is a
significantly different device (at least physically) than the Geobrick
LVM.  At the very least LV is MUCH smaller (15.4" x 4" x 7.2").  It is
still a PMAC2 based controller, but they make a point of the elimination
of analog signaling:
      "The absence of analog signals – required for typical motion
controller/drive interfacing – enables higher gains, better overall
performance and tighter integration, while significantly decreasing
costs and setup time."
This may explain how they managed to make it so much smaller the the LVM
model (which, as near as I can tell, they no longer make).  It might
also help avoid the noise problem that Matthew mentioned regarding the
LVM model.
 From reading various other Tech-talk postings my impression is that the
Delta Tau PMAC controllers are very capable, but complex and require a
lot of effort to get set up correctly.  However, that may be mitigated
to some extent by using the synApps tpmac module (and BNL's page
regarding setup and configuration).
What other controllers are being used?  What are the advantages,
disadvantages, and problems that have been encountered?
Mark Davis
NSCL/FRIB
[email protected]
Stepper Motor Controllers Mark Davis
Prev: Re: Stepper Motor Controllers Mark Rivers
Next: Re: Stepper Motor Controllers Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Stepper Motor Controllers Mark Rivers
