1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: using motor / steppermotor record for Trinamic TMCM-351 controller
To: [email protected]
Date: Wed, 15 Jul 2015 10:20:58 +0200
Dear experts
I guess i need your help / advice again:
We have bought a Trinamic TMCM-351 3-axis step motor controller, and want to control a XY-table with this. It communicates via USB / serial, and we want to run the soft IOC on a connected Raspberry Pi under Linux.
From what i understand by scanning through various EPICS pages and docs, the motor module/record, or, alternatively, the steppermotor module should provide all i need to work with such a multi-axis setup under EPICS.
However, from what i learn from the motor record documentation, there is no direct support for exactly this controller. The controller is fairly simple, and understands plain ASCII / Byte commands send via serial port, so i am pretty sure it is very similar to other controllers which actually are supported.
But how do i proceed now ?
Is there some kind of general interface, where i can just define the needed commands to make the motor record work with this controller ? Or do i have to program a full new driver (starting maybe with one of the existing ones) ? The documentation (i found so far) regarding setting up a controller with motor record is really sparse.
I am not an EPICS expert, but have done some projects with epics before. In particular i am running another similar scanning table, where i did the complete control (for a much simpler controller) only using streamdevice and interconnecting records. But i guess, using the particular stepmotor records is a more elegant way to go ???
In the documentation of motor record, it says: "The following controllers are supported IN ADDIDION TO SOFT CHANNEL SUPPORT".
What is meant with this ?
Any help or advice (including links to some more detailed how-to documentation) is very welcome !
Best regards,
Christian
RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
Re: using motor / steppermotor record for Trinamic TMCM-351 controller Ron Sluiter
Prev: Re: Stepper Motor Controllers Torsten Bögershausen
Next: Re: how NOT to update the record Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Conversion to Hexadecimal Rod Nussbaumer
Next: RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
