1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Prosilica GigE on MAC
To: EPICS Tech Talk <[email protected]>
Date: Wed, 15 Jul 2015 12:54:38 +0200
I found the problem to be in the javascript attached to the image intensity graph.
The script was trying to visit every element and tried to find max and min level in order to adjust graph min/max values.
/Hinko
> On 15 Jul 2015, at 10:53, Hinko Kocevar <[email protected]> wrote:
> Hi,
> I’m trying to get Prosilica GX1050 working on MAC using areaDetector 1.9.1.
> For testing purposes I’m using link-local IP address range with MAC network interface MTU set to 9000.
> CLIConfig from AVT GigE SDK finds the camera and I can get the configuration.
> After running prosilicaApp IOC I soon start getting bunch of errors like this:
> CAC: error = "Host is down" sending UDP msg to 169.254.255.255:5064
> ../online_notify.c: CA beacon (send to "169.254.255.255:5065") error was "Host is down"
> While using CSS OPI the screen becomes unresponsive.
> Using the same setup on Linux Mint causes no such problems.
> Any hints?
> Thanks,
> Hinko
Prosilica GigE on MAC Hinko Kocevar
Prev: Prosilica GigE on MAC Hinko Kocevar
Next: Re: Stepper Motor Controllers Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: JCA 2.1.2 on 64 bit Ubuntu Frank Gribbin
